Think ive ordered wrong crank size!?- Mtbr.com
Results 1 to 8 of 8
    Reputation: tizdaz's Avatar
    Feb 2015
    hi guys, i've just ordered the Turbine Crankset (link below) my frame BB is 100mm & my rear spacing is 197.
    Ive ordered the 100mm / 175 ..but should i have ordered the 190 / 175!?
    I ordered the 100mm / 175 as i thought the 100mm refers to the BB & the 175 refers to crank arm length?
    ...i'm confused!?
    heres the options etc: https://www.tredz.co.uk/.Race-Face-T...ely_117458.htm
    Felt DD10 Fatty
    ..with lots of upgrades ^^
    Rippin da fAt
    Reputation: BansheeRune's Avatar
    With the Turbine, you can swap the spindle readily for any length to accommodate most BB shells.
    Rear spaced 190/197 requires Bti part # RF-2966.
    https://www.universalcycles.com/shop...s.php?id=67411
    Spindle length is 189.5mm for 190/197 compatibility.
    Get fAt, Stay fAt, Ride fAt
    Doctor recommended...
    A Surly Maverick
    Reputation: Dr Feelygood !'s Avatar
    Yes, that is confusing.
    It should have said 170/175 (170mm wide rear hub/175mm crank length).
    You do need the 190/175 set.
    Just send them back and re-order
    Life IS a Beach and then you Corrode :)
    Feb 2015
    thanks guys
    the order hadnt been sent just yet so i rang them & got it amended!
    Felt DD10 Fatty
    Quote Originally Posted by tizdaz View Post
    thanks guys
    It depends on your frame.
    Plenty of 197 frames will take the 170 spaced cranks. I have a Echo and a Farley that both work fine this way.
    But I have a RSD Mayor that need the 197 spindle
    Alaska Turner Mafia
    Reputation: EndoRando's Avatar
    Sep 2004
    Like the mayor said, some frames work with either. I have a carbon Corvus frame with 197 rear spacing. Most I know run the spindle for the 177 width rear hubs, and it works just fine, giving a narrower Q factor. If you have knee issues this might be a concern. For me, the wider prevents any heel contact with stays since I use size 50 winter boots.
    Deceleration Trauma is my middle name
    Feb 2015
    all sorted, they just replaced with the correct one for me before shipping ..infact should be arriving tomorrow in post \o/
    Felt DD10 Fatty
    A Surly Maverick
    Good stuff !
  1. Replies: 8
    Last Post: 06-05-2014, 10:08 AM
  2. Replies: 8
    Last Post: 06-26-2011, 11:26 PM
  3. I believe I ordered the wrong size....
    By KURBDOG in forum General Discussion
    Last Post: 03-22-2007, 05:49 PM
Members who have read this thread: 82
