are there any forks available with 483 mm axle to crown and a straight steer tube?- Mtbr.com
Results 1 to 20 of 20
    Jun 2012
    I am looking for a fork with 483 mm axle to crown with a straight 1-1/8" steer tube. Are there any available out there?
    Reputation: CCSS's Avatar
    Surly Krampus meets those specs exactly.
    Jun 2012
    Sorry, I did not provide enough info. Needs to fit a 82 mm rim with a 4.7x26 fat tire. Prefer a 135mm qr front hub compatibility, but i'm not sure if that will be possible any more with all the more current standards becoming more prevalent.
    Dec 2010
    I'd be interested in a fork to these specs also, however I haven't found anything that has the same geo as the Krampus fork with 135mm dropouts.
    Jun 2012
    Alt of the new suspension corrected frames that are designed around the bluto have that axle to crown measurement, unfortunately all of the forks that I have seen require a tapered head tube, which my mukluk does not have.
    Anchorage, AK
    Reputation: Lars_D's Avatar
    Davis Carver (bikeman.com) would probably make whatever you wanted out of titanium, but it's pretty expensive (about $400). Walt (waltworks.blogspot.com) could make a steel one for a little less, maybe, but the wait is long.
    --Peace
    Jun 2012
    Does anybody know if the ice cream truck fork has a tapered steerer?
    Quote Originally Posted by 98srx6 View Post
    Yes.
    Jason
    Disclaimer: www.paramountfargo.com
    Jun 2012
    What has surly come to be. Producing a fork that can not be used with older outdated frames...
    Guess they drank the non-compatibility koolaid from most of the other manufacturers.
    Reputation: ferrstein's Avatar
    Quote Originally Posted by JAGI410 View Post
    Yes.
    Dammit! Was hoping to fat front my Krampus on the cheap.
    Really hoping someone steps up with a 483mm 1-1/8" fat fork. Not holding my breath.
    Jun 2012
    Quote Originally Posted by ferrstein View Post
    If surly has given up on straight steerers on their forks, you can just about rest assured that everybody else has as well.
    WNC Native
    Reputation: nitrousjunky's Avatar
    It does exist, Soma Battleaxe- Soma Battleaxe Fat Bike Fork
    "I ride to clear my head, my head is clearer when I'm riding SS. Therefore, I choose to ride SS."~ Fullrange Drew
    Reputation: vikb's Avatar
    Give 'em a break. They sell 17 aftermarket forks and every one is 1 1/8" steerer. Not to mention the correct A to C and axle for the bikes they go on.
    When the ICT comes out they'll have 1 fork out of 18 that doesn't fit an 1 1/8" HT.
    They've hardly screwed anyone and I don't want to buy a bike that's stuck in last decade just so 10 people can jack the front ends of their old bikes up with a fork that's longer than stock.
    The important thing Surly does is stock parts so you can keep your older bike going and are not forced to buy a new one because you trashed your fork for example.
    Safe riding,
    Vik
    www.vikapproved.com
    Jun 2012
    Quote Originally Posted by vikb View Post
    My previous post was unsuccessfully semi-sarcastic. I actually agree with you, although I was hopeful as it would benefit myself (I'm 1 of the 10 dummys that can't seem to leave things as they are meant to be).
    But, the next big question is; with surly using tapered steerers, will their next step be to use press fit bb's??
    WNC Native
    ICT DOES use PF BB.
    Sarcasm needs a at the end.
    Safe riding,
    Vik
    www.vikapproved.com
    Jun 2012
    Quote Originally Posted by nitrousjunky View Post
    ICT DOES use PF BB.
    oh boy...
    carbon frame is next I suppose.
    oh boy...
    I doubt it. QBP has Salsa for that.
    Safe riding,
    Vik
    www.vikapproved.com
    Perfect! This'll fat-front my Krampus perfectly. Even better for an ECR - the difference in length from stock will make up for the smaller diameter fat tire (in relation to the 29x3 Knard).
    WNC Native
    That's why I have the info on it saved as well, that is if I don't go back to full fat instead! OR do both.
  1. Tapered fork on a straight steer tube.
    By cottonball in forum Shocks and Suspension
    Last Post: 11-22-2013, 06:10 PM
  2. Replies: 5
    Last Post: 08-10-2013, 08:55 PM
  3. Tapered Steer Tube vs Straight Steer Tube
    By maw77712 in forum General Discussion
    Last Post: 05-24-2013, 10:28 AM
  4. 1.5 tapered vs. 1.5 straight steer tube Benefits
    By jdkobe in forum Shocks and Suspension
    Last Post: 02-24-2011, 09:01 PM
