Are there any 190mm hubs available right now that won't crap out- Mtbr.com
Results 1 to 16 of 16
    I am about to give my LBS lots of moneys to transform my Fatboy into awesomeness.
    Ok so for my summer wheel build I was gonna use Hope Fatsnos, but then I saw that thread. But I also see other threads of other 190mm hubs failing.
    What IS a good option? How about the Salsa? I am not keen on spending i9 money.
    This place needs an enema
    Reputation: mikesee's Avatar
    Aug 2003
    DT Swiss.
    /thread.
    I9!
    arc
    arc is offline
    Sep 2004
    Quote Originally Posted by mikesee View Post
    DT Swiss.
    /thread.
    Have you used these hubs already? I can't find them in stock anywhere and they've only shown up on DT Swiss's website recently.
    Do you know if they beefed up the hub for the wider axles and higher torque fatbikes need or did they just stretch the old 350 hub?
    Buying hubs would be a lot easier if manufacturers would publish weight and torque ratings.
    Aug 2003
    Quote Originally Posted by arc View Post
    I've been using them on my own bike for a ~year.
    I have 20+ sets in stock.
    Apr 2015
    Do they have steel or alu- freehub body?
    Aug 2003
    Quote Originally Posted by ValMSK View Post
    alu stock, steel available.
    Thanks for the input everyone, I asked my LBS to try for DT Swiss first, Industry Nine if DT's aren't available. DT Swiss is much better for the budget, as I'm spending a loooooooooot of money to upgrade this bike
    is buachail foighneach me
    Reputation: sean salach's Avatar
    What Mike said, and the Hadley/Fatback hubs. I9 have a pretty good track record as well.
    DT Swiss.
    /thread.
    Mike, do you know if DT has or will have a 170 option, or is it 190 only?
    Aug 2003
    Quote Originally Posted by BobShort View Post
    As of now I'm only aware of 190/197.
    Thanks! In your extensive wheelbuilding experience what is your goto reasonably priced 170 hub?
    Jun 2013
    Quote Originally Posted by XJaredX View Post
    What else are you adding to the Fatboy?
    Aug 2003
    Not impossible for your LBS to get 'em, but somewhat unlikely. QBP won't have them til ~June, and I'm ~99% sure DT Swiss US sold out their initial shipment already.
    Reputation: Velobike's Avatar
    Ok so for my summer wheel build I was gonna use Hope Fatsnos, but then I saw that thread. But I also see other threads of other 190mm hubs failing.,.
    I have used Hopes for years with no problems. There's no reason a properly* made hub is going to have bearing problems because it is a little wider. In the majority of cases, the problem is more likely to be that users are taking fatbikes into more adverse conditions simply because they can now go there. And then they jetwash their filthy bikes.
    If it's bearings that you are worried about, get a hub that will do the job physically, and replace the bearings with top quality ones. (No point in doing it before they fail though).
    *emphasis on the "properly made"
    Latitude: 5736' Highlands, Scotland
  1. 10mm thru-axle skewer for 170 or 190mm hubs?
    By awai04 in forum Fat bikes
    Last Post: 12-02-2015, 02:38 PM
  2. 190mm frame set up as 29+ ?
    By efuss in forum Fat bikes
    Last Post: 12-05-2014, 07:51 AM
  3. 65mm rims + 4.8" tires on 150/190mm hubs?
    Last Post: 09-20-2014, 05:34 AM
  4. 190mm hubs?
    By lancelot in forum Fat bikes
    Last Post: 03-07-2014, 10:02 PM
  5. 9:zero:7 190mm
    By Tusj in forum Fat bikes
    Last Post: 10-01-2013, 07:04 AM
