Surly Tim strips on rolling Daryl- Mtbr.com
    Wizard of the Trail
    Reputation: Geist262's Avatar
    Hey guys I am building up my 907 and I am having a helluva time getting the rim strips on. They are one piece rubber from surly. I have nobody around and I really want to get this done. Any tips on install? Two people would be better I am sure. Thanks.
    There is no charge for awesomeness......or attractiveness.
    Good rep does not wash out the bad, nor the bad the good.
    Reputation: thickfog's Avatar
    Oct 2010
    Try soapy water?
    CRAMBA Chairman
    Reputation: c0nsumer's Avatar
    I've also liked using Windex or the equivalent glass cleaner as a bead / whatever lube. It doesn't leave as much of a residue as soapy water often does and is still slippery.
    Hybrid Leftys aren't real Moderator
    Feb 2005
    Line up the valve holes, and drop a 6mm Allen through them to keep it positioned.
    The place the wheel on the ground, valve hole up, and work it around. It stretches, and is very tough, don't worry, you won't tear it unless you try really hard. Just work it up and onto the rim.
    Once on, then take a smooth shafted screwdriver, slide it underneath the strip and bridge it across the rims edges, then run it around the rim, to allow you to center it, and undo any wrinkles or folds that happened along the way.
    This is a Pugs not some carbon wannabee pretzel wagon!!
    - FrostyStruthers
    www.mendoncyclesmith.com
  1. Drilled Rolling Daryl/Clownshoe rim on dirt
    By SSBonty in forum Fat bikes
    Last Post: 10-19-2011, 12:06 AM
  2. New Surly rim- Rolling Darryl
    By tscheezy in forum Fat bikes
    Last Post: 12-06-2010, 01:33 PM
  3. screw daryl! help me!!
    By georgezilla in forum Idaho, Montana, Wyoming
    Last Post: 11-01-2006, 08:02 AM
  4. Help Daryl!!!!
    By Ivan the Terrible in forum Idaho, Montana, Wyoming
    Last Post: 10-31-2006, 07:19 AM
