Surly Crankset Weights?- Mtbr.com
    Nov 2016
    Hey
    Does anyone know accurate weights
    for the Surly Mr Whirly (+spindle)
    vs
    the Surly OD cranksets
    -without any BB, or rings, or adapter spiders(whirly)
    I'm having a hard time determining the weights, since even if catalog specs can be trusted as accurate, often times its listing full weight with rings, etc attached. Which makes comparison null.
    I suspect the OD is lighter, since it has an integrated spindle instead of a removable one; on the other hand, it does have spider arms on it....
    I'm aware that they have different features; those features are irrelevant since I'd be using only a single ring on the 58 BCD. Hence my disregard for the default rings and spider adapters... and interest in just straight crankset weights.
    Reputation: baltobrewer's Avatar
    Apr 2015
    No idea on the Mr. Whirly, but my old OD was a heavy sucker. With 2 rings and the BB, it came in at around 900g.
    also:
    http://forums.mtbr.com/fat-bikes/fat...ts-894816.html
    turtles make me hot
    Reputation: NYrr496's Avatar
    Yep. And I just made mine a little heavier. I changed my worn out aluminum 33 tooth ring to stainless.
    If I happen to have mine off the bike for any reason any time soon, I'll weigh it.
    I like turtles
    Jan 2014
    I have both. My first Pugs is a custom build and has the Mr Whirly, and my second Pugs was a SS that came with the OD.
    From visual inspection, it looks like the arms of the Mr Whirly may have a bit more metal on them (by weight), but I'm not certain.
    I prefer the OD, since its easier to use larger rings (no adapter spider required).
  1. Showroom Weights vs Actual Weights
    By Richardwyngaard in forum Weight Weenies
    Last Post: 05-24-2017, 06:32 AM
  2. 2013 Surly weights?
    By thecanoe in forum Fat bikes
    Last Post: 02-13-2013, 10:43 AM
  3. XX1 Mini-Review & Weights, XTR Weights, Race Face Next Crank Weight
    By brentos in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 12-31-2012, 05:03 PM
  4. Hub weights...Syncros, wtb, Hope pro 2 Evo weights
    By RTM in forum Downhill - Freeride
    Last Post: 07-26-2012, 06:44 PM
  5. Crankset weights (XT / XTR / XX / XO
    By chainringX2 in forum Weight Weenies
    Last Post: 05-20-2012, 02:23 AM
