Super-Clydes and tubeless?- Mtbr.com
Results 1 to 27 of 27
    Checking to see if there are any really big riders out there using tubeless setups without any issues. I gained a bunch over the holidays, but I am more thinking about running tubeless on our tandem Pugsley. Combined we are around 300 pounds. I will be using RD rims, most likely split-tube style. Any problems or concerns?
    "Wait- I am confused" - SDMTB'er
    Reputation: jlynn907's Avatar
    Oct 2013
    I don't think you'll have any problems. :-)
    turtles make me hot
    Reputation: NYrr496's Avatar
    I'm running split tubeless Knard and Bud on Clownshoes year round and I weigh about 250 currently. I ride as hard and fast as I can and have never had a burp or anything.
    Whole combination has been trouble free.
    I like turtles
    You will be fine...get Mulefuts if too nervous. I went from split tube Darryl to Mulefut and will never look back.
    Oct 2013
    Quote Originally Posted by jonshonda View Post
    Mulefut's are an excellent, budget-friendly tubeless-ready wheel!
    bigger than you.
    Reputation: Gigantic's Avatar
    270, sometimes more with gear. I've been tubeless for 3 years, I've never had an issue.
    Reputation: masterofnone's Avatar
    I would think you would benefit just as much or more from tubeless than the little guys.
    To appreciate the flowers you must also walk among s**t to know the difference
    Reputation: tyrone.minton's Avatar
    Feb 2010
    I'm 300 without gear. I swapped my new Bontrager Jackalopes with hodags to tubeless and ran about 6psi yesterday on sand and rock. Not a single burp.
    Sent from my VS985 4G using Tapatalk
    I am sticking with my RD's as they are already bought and paid for, plus they can be laced asym for use on my Pugs tandem. Thanks for all the replies.
    Jun 2015
    I just bought a demo Salsa Blackborow and it is set up with Tubeless Clownshoes running Lous. I am new to all this tubeless stuff. I am a 285 clydesdale... I normally carry a patch kit and a spare tube. What should I carry in my pack with tubeless? I have an irrational fear of being stuck out in the middle of nowhere and having to walk out.
    turtles make me hot
    Quote Originally Posted by Mochamaker View Post
    Know what? I have been split tubeless on Clownshoes for three years now and have never had any problem. I do bring a tube with me when I am going to be on long rides in unfamiliar areas. Haven't needed it yet.
    I run a lot of sealant in my tubeless fat tires.
    I like turtles
    bigger than you.
    I'm 15 pounds lighter than you and carried a tube with me for years, but I haven't carried a tube in quite a while and don't really see the need to. Unless you're in remote areas of wilderness or riding trail that is strewn with Sharp rocks, you should be fine. If you have to carry a tube I'd suggest getting a Q tubes superlight downhill tube and strapping it beneath your seat.
    Reputation: schnee's Avatar
    Quote Originally Posted by Gigantic View Post
    me too
    Yamaguchi Cross YT Jeffsy Salsa Mukluk & Vaya Canyon Commuter
    Trying to be helpful
    Reputation: Guy.Ford's Avatar
    Im currently @280, run Maxxis Minion FBF & FBR 4.8's tubeless on Mulefut rims, no issues.
    #THELEGENDMTB
    2016 RSD Mayor
    2018 Diamondback Release 5CA
    I'm at ~360, I just converted my RD's and 27tpi Nates to tubeless. Had to sew up an inch wide gash in the tread and boot it with gorilla tape, but it's all holding up very well at my weight. Tubeless is absolutely not for any specific weight range, as I am on the extreme range for cyclists.
    This place needs an enema
    Reputation: mikesee's Avatar
    Aug 2003
    Quote Originally Posted by deuxdiesel View Post
    How has this worked out for you, on your tandem pugs?
    Jun 2015
    So tonight was riding in the snow, 8 degrees, and ungroomed trails with lots of walker and runner traffic prior to me so lots of bouncing. I was running about 4PSI and I burped and flatted. Was able to pump for about 10 minutes and ride out, but was a bit concerned. Anyone have issues with burps in the cold temps? Riding Clownshoes and Lous. The tubeless set up was done by the LBS before I bought it. It was the managers bike before I bought it.
    Aug 2003
    Which rim and tire?
    Jun 2015
    Clownshoes and Lou's. On a Salsa Blackborow.
    Aug 2003
    No surprise at all, regardless of rider weight. Those aren't tubeless tires, and they aren't tubeless rims. Sure, they can be made to work using "ghetto" methods, but those methods rely on many layers of tape and a certain amount of pressure. Compress the tape or drop the pressure and you get what you got -- air loss at an inopportune moment.
    Glad you were able to pump it back up and ride out.
    The only way to guarantee tubeless success is with tubeless-ready rims like the MuleFut, Jackalope, HED B.A.D., or a few of the carbon options.
    Elitest thrill junkie
    Reputation: Jayem's Avatar
    4PSI for two wheels supporting 350lbs? Assuming this isn't through 6" of powder. Yeah, that's a recipe for a burp. Also, did you measure the PSI when it was 8 degrees?
    Jun 2015
    So do i bag the tubeless for the winter and put tubes back in? If I ride groomed trails at the local nordic trails, or fatbike groomers in Winthrop, I will have to drop the pressure quite a bit to be able to stay within the rules. I rode all winter last year with tubes, 3.7 tires, and less than 4 psi when needed. I may pull the tires apart and see how they converted them to tubeless?
    Mar 2016
    295/6" ride pretty hard with no issues, better result with a tough casing
    You and I might have the same problem that Mike's getting at - on my 29er, I had rims - MTX33 - that worked tubeless 'ghetto' style. It wasn't made for it, but people were successful with them online.
    I kept on getting burps at pressures that made sense. All the people that were successful were quite a bit smaller.
    I tried re-doing the tubeless several ways, but eventually had to give up on tubeless with those wheels. The extra stress of being so big was just too much - the rim and tire interface wasn't snug enough.
    My fatbike now has tubes and tires that are tubeless specific - Nextie carbon rims and Dillinger 5 tires - and it's flawless.
    You might want to consider swapping out those rims for Mulefuts.
    bigger than you.
    What Mike see was getting at is that tubeless success is dependent upon your rims and tires, which in your case, neither are tubeless compatible. You may have better results using a tubeless compatible tire on your rims or your present tires on tubeless compatible rims, but the only surefire way is to use a tubeless rim AND tire combo. Barring that, at your weight, you may have better results with a slightly higher pressure.
    Jun 2015
    I did not, I tested when I left the unheated 32 degree garage at 8PSI, when I got to where i rode it was much softer, (and 8 degrees) I didn't take the time to test, I have ridden at 4PSI before and it was very similar. Next time I'll be more vigilant and test or air up.
    Thanks everyone else, new rims are not an option right now, I guess if I continue to have issues, I'll dump the tubeless for the winter and go back to tubes. My goal is to get a second set of 27 1/2 or 29's to ride in the summer, so running tubes in the winter wouldn't kill me. I just want to be able to ride. By the way, since my original post in this thread, I'm down to 270, so kuddos to me, this fat biking thing may be working out.
    Aug 2003
    Tube is not a 4-letter word -- people have been using them with great success for a lot longer than tubeless.
    Tubeless has less rolling resistance, which means you'll have to ride farther to burn the same amount of calories as you will riding with tubes. If your goal is weight loss, tubes will help you get there!
  1. Tubeless Clydes
    By cpfitness in forum Clydesdales/Tall Riders
    Last Post: 06-20-2014, 07:14 PM
  2. Any super clydes (250+) have their rear shock tuned by Push?
    By t51rmkiv in forum Clydesdales/Tall Riders
    Last Post: 03-23-2014, 03:51 PM
  3. FYI: Heavy Shock Springs for Super Clydes
    By BigJZ74 in forum Clydesdales/Tall Riders
    Last Post: 11-05-2011, 07:28 PM
  4. Any Clydes running Tubeless that are 300+
    By teamx151 in forum Clydesdales/Tall Riders
    Last Post: 09-27-2011, 08:32 AM
  5. Tubeless for Clydes???
    By jdmaum1 in forum Clydesdales/Tall Riders
    Last Post: 03-08-2011, 08:37 AM
