Summer tires 27.5x4.5- Mtbr.com
Results 1 to 11 of 11
    Nov 2018
    New rider, 1st post.
    Picked up a Farley 5, fun bike, rode it all fall and winter. The 27.5 x 4.5 Gnarwhals worked great on frozen old pasture, woodlot bushwhacking, snowmobile track, a lot of steep climbs. I love the big rollover and the aggressive tread.
    My summer riding mix will be more dirt single track with some gravel and pavement. With summer tires I could save the tread on the Gnarwhals and maybe get faster lighter tire. I have the 80mm mulefuts, don't want a 2nd set of rims at this time. My LBS would do the swap he has the 4.5" 120 tpi Barbagazi and 3.8" 60 tpi Hodags in stock. What do you guys think, worth it to change or just grind it out on the Gnarwhals? How do tires hold up to being remounted several times tubeless?
    Donít buy new tires until your old ones are wore out real good.
    Dec 2008
    I have hodag's on one bike and maxxis FBF's on the other. FBF's work well in the summer months.
    Minnesota Off Road Cyclists www.morcmtb.org
    This place needs an enema
    Reputation: mikesee's Avatar
    Aug 2003
    Barbe's for sure, for many reasons.
    Quality tires can be mounted/used/unmounted/remounted many, many, many times, no problem.
    Reputation: bikeny's Avatar
    For what you describe, Barbegazi or Hodag for sure, depending if you want to keep the full 4.5 volume, or want something narrower and a bit faster. The Hodag will drop your BB some though, so consider that. I think saving the Gnarwhals for winter is a good idea, and these tires can be mounted/unmounted many, many times as mentioned without damage.
    If you want to splurge for new wheels at some point, go for some 29+ with something like a WTB Ranger.
    Sep 2013
    If you're using 80mm rims, I would go with the Barbegazis. I would think that all of the 3.8 tires would leave too much rim exposed.
    FYI, I do use 4.5 Gnarwhals for snow but not dirt. Too much grip and rolling resistance...and they're studded.
    Reputation: CanuckMountainMan's Avatar
    Oct 2018
    I've actually got 3 sets of Bontrager 27.5"x4.5's for my Farley 7
    (They were on sale 20% off last year, plus I had a bunch of LBS coupons to use up)
    Studded Gnarwhals for Winter Snow/Ice, Non Studded set for Springtime Mud traction
    and a pair of Barbegazi's for faster dry Summer conditions and occasional pavement use.
    Stock Mulefut 80mm wheels and have not gone tubeless yet, still shopping for a Carbon wheel set.
    Reputation: Tunalic's Avatar
    Feb 2012
    When I got my Farley it came with the Hodags on 80mm Jackalopes and knew the Barbs were coming out soon. Got the Barbs on as soon as I got them. I ride nothing but FL Panhandle Beaches.
    Heres a shot of the Hodags.
    And Barbs.
    2018 Trek Stache 7
    2016 Trek Farley 9.6
    2015 616 Muenzie
    2013 On One Fatty
    2011 Trek Sawyer (27.5+ Alfine 8 spd)
    Nov 2018
    Thanks for all the replies. I went with the 4.5 Barbagazi. Aired them up hard 20/18 psi and did a 12 mile pavement ride. They seemed to roll well for a big tire, I'll see how I like them with lower pressure on dirt when it dries up a bit more. At the least I dropped a LB or more, got a quieter tire, and will be keeping the Gnars sharp for next year.
    One more question for future reference. What's considered optimum rim width for 3.8-4 x 27.5 tires?
    Sep 2013
    Quote Originally Posted by iowaforge View Post
    Many around here are using 27.5 x 3.8 on a 50mm(external) width rim for non-snow usage.
    Aug 2003
    50 to 70mm, depending on how and where they'll be ridden.
  1. 27.5X4 Who's excited? Who's not?
    By crohnsy in forum Fat bikes
    Last Post: 03-21-2019, 02:56 PM
  2. Suzi Q with Barbegazi 27.5x4.5
    By JeremyFXDWG in forum Fat bikes
    Last Post: 03-01-2018, 07:15 AM
  3. Salsa embracing 27.5x4
    By hoboscratch in forum Fat bikes
    Last Post: 09-08-2017, 06:06 PM
  4. frames that fit 27.5x4.5
    By max-a-mill in forum 26+/27.5+/29+ Plus Bikes
    Last Post: 12-28-2016, 11:27 AM
  5. 27.5x4.5 vs 26x4.7
    By JohnJ80 in forum Fat bikes
    Last Post: 05-11-2016, 06:11 PM
Members who have read this thread: 105
