Summer lovin'?- Mtbr.com
Results 1 to 13 of 13
Thread: Summer lovin'?
    Bad cat!
    Reputation: montana_ben's Avatar
    Oct 2010
    Summer lovin'?
    So...if a fella was thinking of building a set of summer wheels (for a mukluk in this case), any preference in these options?
    1. Leave well enough alone and rock the darryls/nates always a possibility.
    2. Build a Marge Lite set and load them with Schwalbe Big Betty's or similar, like in that one pic I saw somewhere.. Very rough calculations show shaving almost 6lbs total from the nate/darryl.
    3. Full on weight weenie with ZTR crest 29ers, and big betty's or similar, shave another lb or so...
    I'm rolling with a lefty up front so fat squish not incredibly important. Bike's about 37 1/2lbs as is. Want to make the mukluk work for a living summer and winter and have fun at both. Any thoughts?
    I'd go with the Marge Lites or even slightly narrower ( 47 to 50mm) trials rims and Husker Du's. It would be a shame to give up all of the fat, it is what makes these bikes fun to ride.
    I've been riding V!Z trials rims with Larrys for a couple of summers and they work great but I am thinking about trying the Marge Lites this summer. I'll be trying HD's regardless.
    Latitude 61
    Bad cat!
    Oct 2010
    Ah ha, thanks for the trials rim tip Syranak, got me searching and found some other posts about this. Something like the trialtech sl with the HD's would be a pretty attractive summer option--a little less weight than the the marge lite and a bit less cash. The Marge lite looks great but choking a little on the cost...cough.
    You weren't by chance running tubeless? The Darryls have been an easy conversion and would hope for the same.
    I agree I don't really want to go the full skinny route...
    Quote Originally Posted by montana_ben View Post
    No tubless for me on the V!Z rims. They don't have as distinct a bead seat as the Newer Surly or Uma rims. They might work ghetto but I have not tried it.
    Latitude 61
    will rant for food
    Quote Originally Posted by sryanak View Post
    Agreed. All the tires I've mounted on my V!Z rims have been loose and require careful attention when installing. I can remove any fat tire from those rims by hand, easily.
    Bad cat!
    Oct 2010
    Interesting... The Nate/Darryl beadlock is like a motorcycle, isn't it? Anyone have any experience with the Trialtech tubeless and fat? Anyone gone for max weight reduction and run front specific trials rims, these would be the 39mm wide ones. 593 grams...Darryl w/ holes is 860. Getting too skinny I wonder?
    I think 39 mm is getting pretty narrow although it will undoubtedly still work. Not much weight savings over the V!Z at 596 g or thereabouts. Also if you are really going for light weight the Nate probably isn't the best choice. A Marge Lite Husker Du or even Marge Lite Larry would probably be a better compromise between overall weight and flotation and tire rim stability.
    You might check on some Trials forums to see what rims they run tubless. If there is a tubless rim that works for trials riders it might be the one to try for fat as well.
    Latitude 61
    Reputation: Velobike's Avatar
    I used 40mm rims for a summer 12 hour race without any problem.
    Latitude: 5736' Highlands, Scotland
    Bad cat!
    Oct 2010
    Thanks for the good advice folks, might give it a try... Would try the Husker's for sure, looks like availability might be an issue for awhile?
    Any tips for sourcing the V!Z rims in the states? Google turns up UK shops...
    I did find this discussion: http://forums.mtbr.com/downhill-free...ls-609169.html
    And this one: http://forums.mtbr.com/fat-bikes/tub...es-507073.html
    Sorry to re-dredge a topic, but sometimes you need hints to find out what to look for!
    turtles make me hot
    Reputation: NYrr496's Avatar
    I just got a Fatback frame. Haven't built the fatwheels yet, but I was considering Salsa Gordos with Ardent 2.4's for warm weather.
    I like turtles
    Losing Ground
    Reputation: Guipago's Avatar
    Feb 2010
    It's too bad Fatback isn't making the 50mm rims anymore. I think a lot of people would get on that summer love. They would most likely be tubeless compatible also. What's up Greg??
    With an aluminum hardtail I wouldn't want to get totally skinny, or stay fat b/c of the weight problem; husky maybe. ~50mm rims + Husker Du's (would) = FUN!
    Bad cat!
    Oct 2010
    Quote Originally Posted by Guipago View Post
    Yes It is a shame the Uma 50 isn't around, I was searching a bit online thinking I might find a pair, didn't realize they'd been done away with. Husker Du/trials rim/tubeless sounds like the hot summer combo to me. Riding the sheet metal screw studded nates was really a blast last night though...I like that tire...just plain mean. A lightweight 3.5ish version of that would be really fun I would think.
    ive got V!Z rims
    my wheel buidler said they were Sh*t not round,and bulging on rims, both as bad as each other
    he recently built me up a marge lite and commented how "thats a proper rim " !
    much easier to build and better quality, If you live in the US go marge lite, dont ship a V!z from the UK
