Results 1 to 8 of 8
    Shreddin the Cul de Sac
    Reputation: Burpee's Avatar
    Studded Tires. Best? Cheapest?
    Best for the $?
    I have read that the pointed studs are not ideal. Not worth the $?
    Other Suggestions?
    https://www.bicyclebuys.com/vee-rubb...-cream/0645259
    keep moving
    Reputation: BlueCheesehead's Avatar
    "Best" depends on conditions and what will fit your bike.
    I have tried the original pointed 45nrth studs. They were better than nothing. Concave bikestuds are a great value and work better. 45nrth XL studs and Terrene crown studs are a step above that, but more $$. I have found the XL studs to be larger than desired as they will grip so well as to tear themselves out of Dillingers.
    This place needs an enema
    Reputation: mikesee's Avatar
    Aug 2003
    that's a screaming deal on a decent tire.
    Sep 2014
    Strange...
    Your link: https://www.bicyclebuys.com/vee-rubb...0645259http://
    Another link: https://www.bicyclebuys.com/vee-rubb...-beige/0645258
    Appears to be the same tire, so better make sure it's the studded version for $109 before purchase.
    Reputation: ADKMTNBIKER's Avatar
    Nov 2014
    there is no one stud solution for all tires.
    except maybe gripstuds. damn expensive though.
    Reputation: Swerny's Avatar
    Mike
    Toronto, Canada
    2017 Trek Farley 9.6
    2017 Diamondback Haanjo Trail Carbon
    2016 Scott Solace 10 Disc
    Quote Originally Posted by MaximumX View Post
    Strange...
    Yes, check the part number vs the Vee site to see which one has studs and which one does not.
    May 2015
    I ran Vee Snowshoe XL with standard "short" studs, and they work- I could ride the ice ribbon we had for XC trails, but they are a little "slow" otherwise. "Traction has a cost"
    Cake Eaters are faster, with fewer short (but concave) studs. (180ct)
    Studding your own Vees you could run tall studs on the outside, shorts to the center, as you see fit.
    I know when the trails turn slick, or if you're heading for waterways, nothing else will do.
  1. Replies: 18
    Last Post: 12-26-2018, 01:43 PM
  2. Dillinger 5 Studded and Dillinger 4 Studded FS
    By Kirkerik in forum Fat bikes
    Last Post: 09-26-2018, 08:40 AM
  3. Replies: 1
    Last Post: 01-10-2018, 06:35 AM
  4. Replies: 101
    Last Post: 12-26-2017, 01:39 PM
  5. Studded Gnarwahl vs Studded Dillinger 4
    By bhanson18 in forum Fat bikes
    Last Post: 11-10-2017, 06:30 PM
Members who have read this thread: 84
