Stronger freehub for Moonlander XT hub?- Mtbr.com
Results 1 to 10 of 10
    Reputation: robselina's Avatar
    Hi All,
    I've got a '12 moonlander with a Shimano XT FH-M756A rear hub. I just had my second freehub fail on it so I'd like to find something a little stronger than the stock replacement. I'm also a little confused about which is the stock replacement. Per the shimano exploded diagram, it would be part # Y3SW98060 (This is the one I used last). However, I think the stock one may have actually been a # Y3BD98010.....
    - Can anyone confirm which is the original part? which is tronger?
    - Are there any other bolt-on replacement freehubs that are stronger?
    - Any easily swaped hubs that wouldn't require new spokes? Other secret sauce?
    Cheers,
    Rob
    Reputation: Gus69's Avatar
    Nov 2012
    XT are crap,I've broken them too. Buy a Hope or a Chris King instead.
    I'm tempted Gus....The Hope Pro 2 evo in particular has my eye...sealed bearings and a 4 pawl freehub sounds worthwhile....
    Elitest thrill junkie
    Reputation: Jayem's Avatar
    Hope is the same basic design, I wouldn't expect any better life out of it. DT's ring-drive design is crazy strong, like having 18 or 36 pawls all engaged at once. Even still, I managed to strip one out after a few seasons, but I've never met a freehub I couldn't break, the DT lasted me about 2x the interval of the shimanos. Chris King would be another great choice for dealing with a lot of torque.
    How Things Work: The Freehub Body - Dirt
    Thanks for the link, it's a good read.
    I swapped on my spare freehub for now, so it's back in service, but I noticed pitting on the bearing cones so new hub is the way to go I think. Now evaluating my options...
    Nov 2012
    If in doubt, go ask the guys in the Clydesdale forum. They will tell you what they can destroy without problems and what they destroy over longer time.
    I ended up buying a full heavy duty Chris King rear hub for my fatbike.
    Yes I'm a clydesdale rider and use high torque and low rpm's and I haven't been able to destroy Hope, DT Swiss and Chris King hubs, whilet most other brands dies within a year.
    bigger than you.
    Reputation: Gigantic's Avatar
    Industry 9
    Reputation: Raleighguy29's Avatar
    Jan 2014
    Quote Originally Posted by Gigantic View Post
    Industry 9
    This guy he gets it!! Love my i9s
    I have Chris King on my mtnbike, and if they made a 170mm hub, I would have one on my Fat Bike. I had a Hope PRO 2 170mm, and had nothing but problems with it. I have since switched to White Ind. Snow White hub, which appears to be much better than the Hope.
    When you are breaking a lot of stuff, look for better bearings, and steel.
    Reputation: MUSTCLIME's Avatar
    My moto fb4 has tought me about freehubs....good vid
    Freehub Body Disassembly/Assembly - YouTube
    On my bike, there was grease on the inside of the paws, so they got stuck down when the grease got stickie and did not engauge. Rebuilt it just like the vid and all is working well.... I am guessing most of the "failed" freehubs have the same problem...but if you have the cash for new shinny new stuff, that is always cooler.
    The bike is never to heavy, you are just to WEAK!
  1. Is T-300 stronger than T-1000?
    By geneiusxie in forum Frame Building
    Last Post: 01-10-2013, 09:16 PM
  2. X9 freehub replacement…compatible with any other freehub?
    By t-stormy in forum Wheels and Tires
    Last Post: 10-01-2012, 08:27 AM
  3. New Superlights stronger?
    By INABIL in forum Santa Cruz
    Last Post: 09-07-2012, 02:57 PM
  4. Need A Stronger Seat!!
    By dangeranger in forum Clydesdales/Tall Riders
    Last Post: 05-01-2011, 09:33 AM
  5. Stronger Shock
    By degs in forum Shocks and Suspension
    Last Post: 04-04-2011, 08:32 AM
