Stripping Lurch- Mtbr.com
Results 1 to 12 of 12
Thread: Stripping Lurch
    djrez4
    Reputation: djrez4's Avatar
    Stripping Lurch
    Lewd, eh?
    The Lurch w/ Bluto arrived today, so my project begins. The plan is to swap as many parts as possible from the Lurch onto an IP-019 frame that arrived a few weeks ago.
    The Lurch:
    The IP-019:
    Why? Because, after selling my old Rip9 for $1745, I have a budget of approximately $1745 to build a fat bike. So far, I have $2043.60 into the whole shebang. I'm hoping to recoup something by selling the Lurch frame w/ stem, bars, seatpost, and front derailleur. If everything works out as planned, I will have a carbon fat bike with both rigid and Bluto for under $1800. Realistically, if I can keep it under $2000, I'll be mighty pleased.
    The bike will be a rolling advertising platform for the website, so I'm calling it a tax deduction.
    The lettering on the IP-019 is standard adhesive vinyl. I got it from QuickStickers.com for $30 or so, shipped.
    Issues so far -
    1) Lurch has a top-pull front derailleur and the IP-019 is designed for a bottom pull. This will speed up my 1x plans.
    2) Different sized seatposts, so I'll have to buy one for the IP.
    Reputation: WSUPolar's Avatar
    Sep 2014
    I'll follow this... tempted to do the same with my Borris X9.
    djrez4
    Slight hiccup. The downtube interferes with both sides of the Bluto.
    Reputation: Aceldama's Avatar
    Jan 2005
    Definitely double or triple check this (probably in the Chinese Carbon Fatty thread) but I think the headset lower race that you need is the cane creek HD-8880.
    Yeah its like 3 or 5 mm clearance it needs. I think I just rad that. Subbed BTW.
    djrez4
    I know the Cane Creek/Salsa race provides 3mm, which may be enough. CK makes a 5mm race, but only for 1 1/8". There may be an On One 5mm option. Niner makes one as well.
    Another minor detail: cables and housings are too short, even though the IP is supposedly a smaller frame. Easy enough to fix.
    Thread title vs. content dissapoints.
    djrez4
    Quote Originally Posted by jonshonda View Post
    Better?
    (PS - do not GIS "Lurch naked")
    Any updates?
    djrez4
    Stuck trying to get the thru-axle kit from Novatec to convert the rear hub. I emailed Henry on Wednesday, but haven't heard back yet.
    If it takes much longer, this project may jump in price when I go with some carbon wheels much earlier than planned.
    Quote Originally Posted by djrez4 View Post
    I'm trying to do the same for the 12QR, let me know what Henry comes back with. I have an email out to him as well - if I hear something first I will share.
    djrez4
    If you would have used the FM-190, am I correct in thinking that you would be able to use your 190mm x 12 QR? I only ask because I wanted to do the same and have a set of Rolling Darryls that have the same 190mm x 12 QR rear hub. If I buy a frame I don't wanted the added cost of buying and building a new set of hubs.
  1. The Lurch Lounge
    By rex615 in forum Fat bikes
    Last Post: 03-08-2019, 02:45 PM
  2. Boris Brut vs. Lurch vs. Sturgis
    By back bowl in forum Fat bikes
    Last Post: 01-12-2015, 06:16 PM
  3. motobecane lurch versus surly pugsley
    By AdventureRider in forum Fat bikes
    Last Post: 07-29-2014, 07:51 AM
