Strange Request - Post Pic of bottom yoke- Mtbr.com
Results 1 to 17 of 17
    Apr 2013
    Hey All . . .
    I'm looking to see the bottom yoke on non Norco fat bikes (I have a bigfoot). The Bigfoot's bottom yolk has open holes (3/8 inch) which allows water and sediment into the frame and then into the BB.
    Oh . . . please state make and model as well.
    Tks
    Loud tyres save lives
    Jul 2013
    Have you got a similar photo of your own bike you can post so I can get an idea exactly what you're looking for?
    John
    2014 Trek Fuel Ex 8
    2015 Trek Farley 6
    2016 Trek Stache 7
    Reputation: rex615's Avatar
    Aug 2014
    Motobecane Lurch 22"
    Is this what you are looking for?
    Apr 2013
    You got it Rex.
    Even a shot from above would be fine.
    Rex . . . is that hole threaded?
    Aug 2014
    Quote Originally Posted by NLSpruce3 View Post
    You got it Rex.
    The hole with the blue arrow is threaded (but you already knew that)
    The hole with the pink arrow, I don't know. I can check tonight.
    I'll comment that the Salsa Mukluk does not have the hole, but our LBS has seen numerous cases of water/grime getting trapped in there from getting in the frame somewhere (the other hole?). They actually suggested drilling out a hole to prevent buildup. It would be easy enough to plug, then pull plug when you want to drain.
    Apr 2013
    Thanks . . . I actually meant the blue one.
    The pink one is probably not threaded as it is a "drain hole" for the BB.
    OUW . . . its my experience that water and debris enters through the blue hole.
    In some cases it may be threaded for use with a cable guide for a bottom pull FD.
    Reputation: shiggy's Avatar
    Dec 1998
    Re: Strange Request - Post Pic of bottom yoke
    The blue "hole" is a fender mount braze on. If you think water is getting in through it, put on a bolt.
    And neither of those holes are even close to 3/8" in diameter.
    mtbtires.com
    Aug 2014
    The pink hole is also threaded, it is probably an option for one of those plastic cable guides for the derailleurs.
    As shiggy points out it is relatively small, about an eight inch.
    EDIT. Just saw bme107's response.
    nothing to see here
    Reputation: Stevob's Avatar
    Quote Originally Posted by rex615 View Post
    Restraining myself from a couple of inappropriate, tongue in cheek responses.
    I see hills.
    I want to climb them.
    Aug 2014
    Quote Originally Posted by Stevob View Post
    Pink was probably not a good color choice, come to think of it neither would have brown.
    nothing to see here
    yeah, and I doubt Shiggy would be happy about his eight inch being called small.
    I see hills.
    Apr 2013
    Tisk Tisk :-)
    May 2013
    put a grease zert in there (red arrow) and pump the BB full
    Most BB's have a sleeve on the inside to protect the bearings from water/dirt. Frames almost always have venting holes on them for the welding process, so it is near impossible to make the frame itself water tight.
    Reputation: vikb's Avatar
    Quote Originally Posted by OUWxGuesser View Post
    +1 - Since I'm generally not running a front or rear derailleur I have left the hole under my BB open on my Surlys to let water that gets in the seat tube drain out.
    I don't ride my bike if the hubs or BB would get submerged. I carry it. So water isn't getting in there.
    Safe riding,
    Vik
    www.vikapproved.com
  1. Strange request - realistic valuation..
    By philstone in forum Ibis
    Last Post: 06-27-2013, 10:12 AM
  2. Strange Marzocchi fork dimension request
    By GMF in forum Vintage, Retro, Classic
    Last Post: 04-13-2013, 09:48 AM
  3. **URGENT** Obsolete Bottom Bracket Part Request!!!
    By mtnbecky in forum California - Norcal
    Last Post: 03-13-2012, 10:35 PM
  4. Strange Request
    By mwestra2 in forum Washington
    Last Post: 10-27-2011, 08:49 AM
  5. Replies: 1
    Last Post: 09-05-2011, 05:26 PM
