SRAM GX fat cranks- Mtbr.com
    Sep 2015
    SRAM GX fat cranks
    Looking at a used sram GX fat crank. It has 100mm BB. I have a 197 rear 907 Tundra. listing says it fits 197 rear 907's.
    It has the direct mount chainring. It comes with the following:
    - New 30t narrow wide sram chainring on spider (for 177mm rear end bikes)
    - Used 28t narrow wide wolf tooth flat ring mounted (for 197mm rear end bikes)
    - Used 26t narrow wide wolf tooth flat ring (for 197mm rear end bikes)
    Can the spider be flipped like some chainrings to give clearance for a 197 rear? Just wondering if it would be possible to flip the spider and use the 30t as well as a 32t oval 104bcd ring I currently have.
    Reputation: dbhammercycle's Avatar
    You've been looking at our local Craigslist... I saw that ad too.
    I'm not sure if you can flip the spider. I think there is a machined out area for the spider to fit on the drive side crank arm. I'm not sure it would fit well when reversed, but I honestly don't know.
    I don't know why,... it's just MUSS easier to pedal than the other ones.
    Reputation: Fat-in-Fundy's Avatar
    Feb 2015
    Here's a pic of the 30T ring on the GX DM spider, can't be flipped so I think you'd have to get a DM ring if you wanted to go that route.
    '18 Norco Ithaqua SL
    '16 Salsa Bucksaw GX1
    '14 Salsa Mukluk 2
    Dec 2008
    Here is a picture of the bike they came off of FYI, check your email.
    Minnesota Off Road Cyclists www.morcmtb.org
  1. Replies: 12
    Last Post: 07-14-2015, 01:27 AM
  2. Cranks Cranks Cranks..BB30?
    By 29or6to4 in forum Singlespeed
    Last Post: 05-26-2012, 02:13 PM
  3. fat fat fatty fat fat fat
    By evilbeaver in forum Riding Passion
    Last Post: 12-10-2006, 01:23 PM
  4. Cranks, cranks, cranks!
    By notsofastanymore in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 09-18-2005, 09:58 AM
  5. cranks, cranks, cranks, ugh!
    By Motivated in forum Weight Weenies
    Last Post: 11-02-2004, 05:54 PM
Members who have read this thread: 8
