Split tube or tape?- Mtbr.com
Results 1 to 31 of 31
    Split tube or tape?
    I've decided to go tubeless, as my trails are loaded with thorns. After spending quite a bit of time in the archives looking at old posts, I'm a little confused on the best way to proceed. I tend to switch tires quite often and only have one set of wheels (RD's). Using tape (gorilla tape, packing tape, or whatever) would seem to be less fuss than the split tube for my situation or am I wrong? I am out of the loop as far as riding with people doing the tubeless thing, no one here to share experience. Reading old posts, it seems the tape method might be more finicky to get right. I suppose this is like asking which is better, Coke or Pepsi. Personally, I'm a Dew guy! Thanks for any insight.
    Split tube. It's easy and proven, and unlike gorilla tape, it's really easy to remove.
    Jason
    Disclaimer: www.paramountfargo.com
    Reputation: thecanoe's Avatar
    Split tube or tape?
    I've been split tube on my MLr for three years with no problem. If you don't trim the tube too close to the rim you could probably reuse the tube.
    Santa Cruz Tallboy
    Moonlander
    turtles make me hot
    Reputation: NYrr496's Avatar
    Split tube with a 24" Q Tube works perfectly.
    I like turtles
    All fat, all the time.
    Reputation: Shark's Avatar
    Feb 2006
    The tape started leaking for me (bad roll maybe I dunno), but split tube has been working well.
    Reputation: tundratrader's Avatar
    Split tube or tape?
    I don't fully understand the split tube and how it saves weight? I am using gorilla tape and it is working just fine on my rd's with nates.
    Reputation: AllMountin''s Avatar
    Re: Split tube or tape?
    Split tube saves weight because you replace a heavy fat tube with a light, undersized tube.
    Split tube or tape?
    So you put the tire bead over the edge of the split tube? Is this an easier way to if you want to swap tires often? I have wanted to switch my nates for some old endo's for beach only rides a few times but didn't want to start back over.
    Quote Originally Posted by tundratrader View Post
    Im with you...what does a 24inch tube weigh, plus stans, and a valve stem....or get a q light 26 inch 2.7 tube that weighs 240g.
    I'm not really worried about the weight of any of it. I just thought the split tube might be a little more finicky when using multiple tires on a single rim. Once again, this is purely an uneducated guess- no hands on experience with either set up.
    Split tube or tape?
    Well I used gorilla and Stan's. I will do homebrew next batch but live in a little town that didn't have the latex. My dad made some up and it was weeping green which they said in the homebrew thread was normal but seamed weird to me.
    will rant for food
    FWIW, tubeless is worth doing even if you don't save any weight. I had purposefully been avoiding it because I was told that I'd be addicted to it from there on. I tried it this summer and thought it was nice. Rolls a bit better, hugs a bit better, increased flat protection etc. Weight reduction is one gain out of a list of gains.
    Feb 2006
    Or say f' it and ditch them both..... nextie with just a wrap of Stans-like tape to seal spoke holes.... First shake down ride on front wheel today was nice
    nothing to see here
    Reputation: Stevob's Avatar
    Quote Originally Posted by Dr.Mushy View Post
    I re-use split tube all the time. Not an issue, even with the tube trimmed down to just a few mm above the rim line. My rims (On-One Fatty) absolutely suck balls when tried with just tape.
    I see hills.
    I want to climb them.
    since 4/10/2009
    Reputation: Harold's Avatar
    Quote Originally Posted by Shark View Post
    I have been wondering how well this would work. I got my nexties drilled with no offset so as long as the adhesive held well enough, i was wondering if one wrap would work.
    Reputation: mtuck1's Avatar
    One wrap of (Gorilla) tape has worked perfectly in my HED Big Deal.
    Reputation: brassos's Avatar
    Aug 2014
    split. Used 24x 2.1 to 2.4
    The extra over the edge of the rim, 1/2" or less on 85mm rims will let you easily re-install tires.
    Reputation: tobimaru's Avatar
    Aug 2014
    Asked myself this question today and decided to try the tape only method first with Stans sealant. If I have any issues I can tear it all down and add an undersized split tube for a few dollars, and the tape can stay as added sealer/protection; right? Seems foolproof
    Feb 2006
    Quote Originally Posted by NateHawk View Post
    Seemed to work well, there was minor leaks around the bead for the first mile or so, then sealed perfectly.
    I rode some nasty stuff today, was flawless.
    since 4/10/2009
    Sounds promising! I think I will use this method to start with.
    Split tube on two fatties for two years now riding year' round. Go Ghetto!
    Laramie, Wyoming
    Reputation: alphazz's Avatar
    Oct 2012
    Quote Originally Posted by JAGI410 View Post
    I haven't found Gorilla tape very difficult to remove. Cut across the tape and pull it from the rim.
    Quote Originally Posted by NYrr496 View Post
    I've set up numerous wheels with tape and I think it works perfectly as well.
    Quote Originally Posted by Drew Diller View Post
    Drew is right on.
    Once you go with the tubeless ready rims, you'll never have to think about tape and tubes again. Save your lunch money and buy a set, you won't regret it.
    NeedGod.com
    Reputation: Barheet's Avatar
    If you're going to be changing tires a lot, I would gravitate toward the tape method. Gorilla tape has been working well for me except at really low pressure. When winter hits and I need to run low pressure, I'm planning on either split tube or tube with Stan's.
    That said, it sounds like lots of folks use split tube with great success. My only concern is that it might be a little tougher method if you are wanting to change tires a lot.
    Nathan
    Downcountry AF
    Oct 2013
    did my first split tube fat tire today. worked like a charm. after putting reflective tape in the pattern i wanted i used a strip of foam to fill up the center of the rim a little. i think that helped the tire to seal almost instantly when i inflated with air. will be able to re-use split tube for next time. i like this method. works great!
    only the Blue tape is reflective, find out later tonight how it looks when lit up at night.
    Attachment 923464Attachment 923465Attachment 923466Attachment 923467Attachment 923468
    dvn
    dvn is offline
    Reputation: dvn's Avatar
    Looks like a lot of work. Orange Seal tape and sealant. Done.
    "Either way it doesn't really matter, I just got back from a bike ride."
    > dbhammercycle
    sluice box
    Reputation: Co-opski's Avatar
    Oct 2013
    Velocity Dually 26" innercity tubeless with HuDu's. 24" q-tube cut open, little Stans, shot of air, trim flap, ride.
    Feb 2006
    Drew is right on.
    Tubeless ready carbon fat rims? Sounds pricey I'll ride my nextie's & spend the extra $$ on beer....lots of beer!
    Oslo, Norway
    Feb 2012
    Two loops of one inch wide foam insulation tape along each sidewall. Six loops of Glad Pack or other type of plastic wrap. Install valve. Install tire and goop. Easily inflate with the skinniest of mini pumps. Cut off excess Glad Pack. Shake and ride.
    Glad Pack is near weightless.
    Reputation: davesupra's Avatar
    Sep 2013
    I used gorilla tape on my clown shoes with a bud and nate. It's been flawless.
    DaveH
    '15 Salsa Horsethief
    '13 9:ZERO:7
    '13 Trek Domane
    '16 Salsa Fargo
    Reputation: drolic's Avatar
    Dec 2013
    OP, I didn't look at your other posts but you don't mention what bike, wheel, or tire you have? Not all wheel and tire combinations are winners when it comes to tubeless. Some experimentation is necessary. But, I'll go ahead and cast my vote for split tube. When it comes to fat bikes I'll up the ante with the foam inserts.
    I actually just updated my write up of my experiment with filter floss (vs foam) on my Boris.
    http://forums.mtbr.com/fat-bikes/fil...be-907209.html
    Alright, I tried gorilla tape on my new Mulefut rims. The tires seated better/faster/easier than my "proper" tubeless non-fat rims. After the beads popped into place (less than 3 seconds with air compressor), I was done. No rubber trimming necessary. I recommend the tube with "tricky" rims, but there is absolutely no need with the Sun Mulefut. It's a great rim!
    Jason
  1. Tape vs split tube for fatty tubeless
    By Dustin Mustangs in forum Fat bikes
    Last Post: 06-28-2016, 08:02 PM
  2. Filter Floss as a fat rim filler (split tube)
    By drolic in forum Fat bikes
    Last Post: 09-17-2014, 06:54 AM
  3. what is split tube tubeless?
    By tim208 in forum Fat bikes
    Last Post: 03-29-2014, 03:42 PM
  4. Tubless Ready (UST) tire with split tube ghetto setup?
    By kapusta in forum Wheels and Tires
    Last Post: 11-01-2011, 03:12 PM
  5. 29er split tube tubeless question
    By p nut in forum 29er Bikes
    Last Post: 03-19-2011, 05:30 PM
