Split tube schrader- Mtbr.com
Results 1 to 12 of 12
    May 2020
    Split tube schrader
    I'd like to convert to tubeless using the ghetto split tube method and want to use schrader valves.
    I'm trying to track down suitable tubes and am hoping for some suggestions. Rims are 80mm so I'm not sure what size tube I'll need...
    Also, I'm curious if it's possible to use a tube with standard schrader valve stems (non threaded) or is a fully threaded stem mandatory for this method?
    Thanks in advance!
    Rippin da fAt
    Reputation: BansheeRune's Avatar
    Threaded or non threaded works. Just hit a website like universal cycles and order up the 24" x fat tubes and go to town. 24" will fit snugly on the rim and make life easier in the setup process.
    Get fAt, Stay fAt, Ride fAt
    Doctor recommended...
    May 2020
    Quote Originally Posted by BansheeRune View Post
    That's great to hear that I can get away with a regular non-threaded stem - that will make it much easier to find a suitable tube. I'm guessing it will just seal itself either way? I've never done this before...
    As for tube size, I've heard of people using 20" as well.
    Any reason to choose 24" over 20", assuming they're both wide enough to cover the 80mm rims?
    If I can't get the right fat tubes, what is the minimum/lightest size that I can get away with? I'm buying in Canada so searching amazon/etc for parts.
    Cheers
    This place needs an enema
    Reputation: mikesee's Avatar
    Aug 2003
    How do you keep the stem from pushing into the rim when inflating if it isn't threaded?
    Reputation: Redlands R&C's Avatar
    Dec 2013
    Quote Originally Posted by mikesee View Post
    I agree with this. I have had the best split tube luck using fully threaded stems.
    On my junky Turnagain FR80 rims, I ended up using a 20" x 3.5" inner tube for the split tube. It did require more stretching to fit the rim, but was very tight fitting in the end. The 3.5" width was definitely overkill as I trimmed a lot of material off, but I wanted to make sure there was more than enough since it was a sacrificial tube.
    Silly bike things happening.
    May 2020
    So am I better off just going the gorilla tape way then?
    Scott Big Jon with Syncros rims and 4.8 jumbo jim tires - nothing tubeless ready.
    I've read that people have had difficulty with this combo so I want to keep it as simple as possible.
    Lightweight and reliability obviously needed!
    Thanks again
    Jan 2014
    I'm lucky enough to have tubeless ready rims so I've always purchased Schrader Valve sans tubes.
    If I was to guess how to accomplish inflated without a threaded valve I would use tape around the valve, rim and use a mini vice tool needle nose to keep it in place.
    https://www.amazon.com/Crescent-Curv...sparkle_asin_0
    Dash Pt. State Park (Tacoma), Big Sky Montana during Snowboard Season, Duluth Mn, a couple of times of year incl. Xmas.
    Quote Originally Posted by Palomini View Post
    So am I better off just going the gorilla tape way then? ...
    A big NO to Gorilla Tape.
    It's a crap shoot on if Gorilla Tape will work. There are other tapes where they'll actually publish their specs, like strength, elongation and adhering strength. Tests done on Gorilla Tape are all across the map. No way to know if it was a good batch or a bad batch, a shipment that wasn't heat damaged in transit or simply aged out. That they won't publish the usual tape specs is a good warning sign. Every application I've ever tried with Gorilla Tape has failed. Others have experienced it failing, working poorly, working 'normally' or working very well. You will not know if the roll you got will work until you use it and try and rely upon it.
    Go find the threads that have already covered going tubeless. Different methods, different tapes/wraps, etc., including which work consistently well, and with tips on what is required (or not) for obtaining success with a particular product. And if a particular product did/didn't work with _____ sealant.
    Different people have their favourites as to independent stems.
    Mine (schrader valves)
    http://949racing.com/lugs-valves.aspx
    Crazy on this ship of fools...
    Mar 2011
    949Racing valve stems are really nice.
    Rippin da fAt
    By not being a clumsy freakin oaf. Is common sense ever going to be required, ever again??? Just remember to simulate a bull in a china shop every time you use a freakin tire pump!
    While I am not a fan of threadless stems, they will work however, threaded is good for a supported stem.
    Quote Originally Posted by Redlands R&C View Post
    Turnagain, Weinman and a few others, just never, ever...
    Cheers
    Come to think of it, a dirt bike tube would give you a split tube schraeder setup without too much drama. Perhaps a couple used tubes at a local motorcycle shop... Fronts will be less effort to stretch over a fat rim.
    Reputation: AllMountin''s Avatar
    Small ziptie at the base of the schrader valve works a treat. Cinch it tight and it bites the rubber. Specialized tubes ime are threaded. 20 inch makes a tight fit on 26 inch wheels. For 27, a 24 tube is better.
    Split tube is superior to tape in most situations. Rubber on rubber makes a better seal than tape on rubber every time. I think it's the best sealing interface out there, regardless of price. Think fatty stripper without the possibility of valve seal issues.
    May 2020
    Awesome tips! Thank you everyone
  1. Split Tube w/ 26" Tube on 26" Rim
    By jonshonda in forum Fat bikes
    Last Post: 04-16-2019, 11:10 PM
  2. Schrader Valve Tube tool
    By NEPMTBA in forum Tooltime
    Last Post: 04-06-2012, 04:57 PM
  3. Fully threaded BMX schrader tube
    By scuver in forum Wheels and Tires
    Last Post: 09-16-2011, 08:19 AM
  4. Schrader tube into Mavic UST rim?
    By allroy71 in forum Wheels and Tires
    Last Post: 07-13-2011, 06:12 PM
  5. Replies: 13
    Last Post: 08-21-2006, 02:49 PM
Members who have read this thread: 48
