Spesh fatboy aluminium frame lower headset bearing angle?- Mtbr.com
Results 1 to 6 of 6
    Dec 2008
    Canít seem to find the specs on the fatboy lower headset bearing
    Not sure if itís 36x45 or 45x45 degrees for the aluminium fatboy frame
    Thanx in advance
    Professional Crastinator
    Reputation: Fleas's Avatar
    I think those should be millimeters, not degrees.(?)
    Does this make any sense? https://bicyclepartsdirect.com/endur...-bearings.html
    -F
    It's never easier - you just go faster.
    Dec 2008
    Quote Originally Posted by Fleas View Post
    -F
    Sorry should have given more info. The bearing specs will be something like below
    40mm x 52mm x 6.5mm 36x45 degree
    For example
    Dec 2008
    -F
    Cheers, just not 100% sure that the alloy frames are 45x45 degrees, think the carbon frames are definitely 45x45
    Dec 2008
    Think itís 45x45 campy and not 36x45 degree cane creek, but would love some confirmation.
    Dec 2008
    Actually doesnít matter
    The angle in the frame is 45 and the other bearing degree is related to the crown race angle
    Used the correct crown race so all good
    Pics for example, not correct bearings
    Thanx for the help
  1. 2012 Epic Comp Carbon lower headset bearing
    By Pipo_btt in forum Specialized
    Last Post: 12-26-2016, 03:29 AM
  2. RM Blizzard -30 vs Specialized FatBoy/FatBoy Comp?
    By Engineer90 in forum Fat bikes
    Last Post: 10-23-2015, 12:13 PM
  3. Fatboy Trail or Fatboy with Lefty Conversion
    By Khemykal in forum Fat bikes
    Last Post: 10-12-2015, 10:34 PM
  4. Spesh Fatboy vs. "budget" fat bikes?
    By StuntmanMike in forum Fat bikes
    Last Post: 08-23-2014, 07:58 PM
  5. Spesh Fatboy vs. "budget" fat bikes?
    Last Post: 08-22-2014, 05:34 PM
Members who have read this thread: 25
