Specialized fatboy bottom bracket creaking noise- Mtbr.com
Results 1 to 7 of 7
    Jun 2012
    I bought a Specialized FatBoy a few months ago, and now the bottom bracket is make it creaking noise, Iíve greased it several times but keeps coming back. I understand this is a common problem with specialized being the bottom bracket shell is a non-threaded design.
    Has anyone been experiencing the same problem and what have you done to fix it other than taking it apart and greasing it every week?
    Jul 2015
    Mine had been making some weird creaking noises from around the bottom bracket area shortly after I bought it. One thing that'd make the noise come back was if I rode the bike hard and got any dirt on the cranks. Turns out it wasn't the bottom bracket though; it was the chain. After cleaning it and putting on a liberal amount of dry lube the noise went away.
    Yesterday my bike developed a weird "rubbing" noise from the back tire. It'd come and go depending on how hard I was pedaling. What was causing it was the cap that covers the wheel bearing on the non-drive side had worked itself loose.
    Is it properly torqued? Have you eliminated all other possibilities like the crank arms, pedals, shoes, the bearings? Wear other shoes, swap out pedals, torque the BB correctly and then replace the bearings using a proper tool. At that point talk with your shop if you haven't done so already.
    Reputation: watts888's Avatar
    Oct 2012
    it's amazing how my old cheap 29er with a square taper bottom bracket never gave me creaking sounds, but when I upgraded to an external bottom bracket, it creaks. Heavy handed assembly with cheap bikes vs. exact torquing specs for carbon fiber. sometimes, simplicity and heavy is better.
    Reputation: duggus's Avatar
    It's because they come with a crap press fit bottom bracket. I have 2 friends with fatboys and they had the same issue. Press fit should go away.
    ...Be careful what you're looking at because it might be looking back...
    Aug 2014
    My Fatboy's original pf30 bb died within the first couple months. I'm not sure if it's a quality issue with the original bearings, but the replacements lasted a bit longer. They still felt pretty rough though (not completely blown like the originals) when I finally replaced the crankset with a X9 and went with a GXP bb. Given the added stress on the bearings (100mm vs 68/73mm bb shell), I have to imagine that the more outboard you can get the bearings, the stronger/more durable it will be.
    I have a 15 or 16 Fatboy, and I apparently had a good run with the first BB, as we just replaced it in March, but it's been maybe 10 rides and the new BB is shot already.
    What's the latest word on a good bottom bracket for this bike? I don't want to go crazy because I'm selling it but I want to make sure the next owner doesn't have to replace it anytime soon.
    It has a Raceface Next carbon crank if that matters. Thanks!
  1. Specialized Fatboy Pro Bottom Bracket
    By BonesNis in forum Fat bikes
    Last Post: 12-12-2017, 09:19 AM
  2. Specialized Fuse bottom bracket creaking noise?
    By MTB9488 in forum 26+/27.5+/29+ Plus Bikes
    Last Post: 09-03-2015, 08:02 PM
  3. Specialized Fatboy bottom bracket issues and questions
    By fatboy in nz in forum Fat bikes
    Last Post: 08-18-2014, 05:07 PM
  4. Creaking noise from bottom bracket
    By johnb in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 03-17-2014, 01:48 AM
  5. Giant Talon 2 29er crank/bottom bracket creaking noise
    By prince_ruben in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 07-08-2011, 10:58 AM
Members who have read this thread: 32
