Spam :  Custom RSD Mayor size XL with Mendon Fat Lefty-20190329_134040.jpg
https://classifieds.mtbr.com/showpro...product=116548 link here
Price is Firm. $1500 CASH picked up in Hayward or buyer pay shipping and paypal fees
110 fat bike RSD Mayor with lefty Fork size XL for rider 6' to 6'5" or taller. anyone thats shorter than 5'11 is not recommended.
Bike is currently as shown in pictures with a box of parts, setup for shipping all bolt on parts are not installed. I went over the bike there is 3 cosmetic blemishes shown in photo. 1 deep nick in the headtube, 1 deep ding in rear rim. some scuffs and scratches on the lefty fork and clamps. everything is either new or low miles functions 100%, there would be no suprises. no noises no play, wheels are true, hub bearings are buttery, lefty is serviced with no miles by Mendon Cycle Smith Craig himself. This would be built into a solid bike.
Assembly Requirement
Approx 80% assembly is required. everything can be done at home with a set of allen keys. BB and Crank are installed. Headset cups are pressed. The Bar and Stem are bolted .
Brake Levers, Grips and Shifter Lever Needs to be installed. Lefty fork needs to be setup and clocked for 51mm offset
The Rear Derailleur needs to be installed. All Cables needs to be cut to length and need to be routed. Brakes Calipers need to be bolted to the Frame and Fork. The Fork Steertube needs to be cut desireable legnth and star nut needs to be installed. The 6 bolt Brake Rotors are installed and Tires need to be inflated.
Total time required for Assembly is about 45min to 1 hour for a bike mechanic.
Note: Assembly should NOT be attempted if you have never assembled a bike before. A Bike that is NOT properly assembled could result in potential serious injuries.
Brand new parts are:
Frame: XL FAT Bike Custom Hydroform AL6061 Finish Raw alloy with clear coat,
Headset: Cane Creek ZS-44
Handle Bar: Cannondale C2 alloy riser bar
Grips: Giza Lock on
Crank: Race Face 175mm CINCH DM
BB: Race Face DH sealed
Brakes: Avid BB7 Grey w/FR5 silver Lever
Cables: Jagwire black housings
Rear Axle: SRAM Maxle Ultimate 12x197mm
Pedals: Cycletrack gold and silver machined sealed pedals
Saddle: UGP RITZY
Used Parts:
Fork: 80mm Lefty fork with Air, PBR lockout rebound adjustment. currently running 3 spacers as shown in photo, can be removed and become 110mm travel
Stem: Edge 100mm Riser stem
Front Wheel: Gold Surly Marge lite 65mm with Connondale lefty hub offest laced
Rear Wheel: Gold Surly Marge lite 65mm with FatLab rear hub 6 paws on 24T ring= 72POE set up 197x12mm, Also Have end caps to make it 190mm QR as well. Shimano 8/9/10/11spd, comes with the rear hub 190mm QR conversion axle caps and skewer.
Chain Ring: Race Face 28T NW Ring
Chain: 10sp hollow pin with quick like and extra links
Cassette: SunRace MS3 10-speed Cassette 11-42
Rear Shifter: Sram XX cabon 10 speed
Rear Derailleur: SRAM X9 type 2.1 10spd short cage
Rotors: 160mm rotors
Seat Post: FSA Gravity Cabon micro adjust
Tires: Specialized Groundcontro 26x4.0 with tubes
