Results 1 to 15 of 15
    snowpak fork question
    so - why are surly hubs not compatible with this fork
    more importantly - Im assuming 135 mm rear hope pro II's are
    On their website it says it was designed for 135mm front hubs. So it might take some work, like filing dropouts and adding spacers for the brake offset, to get a Hope Pro Rear in there.
    They take 135mm front hubs. The disc brake surface on a rear hub is 5mm further inboard.
    Reputation: NOBBY605's Avatar
    Unfortuantely there is now 135mm rear disc spacing....and 135mm front disc spacing....both are front hubs.
    Paul front disc spacing..(rear disc spacing in the works) FITS SNOWPACK
    Surly, Salsa..rear disc spacing
    Fatback's front hub options will fit as well.
    White Bros. website says that they plan to make a disc caliper adapter that will allow the use of rear-brake-spaced hubs.
    mmm
    cant I just shim the brake disc out 5mm
    Quote Originally Posted by cozz View Post
    mmm
    You could. I haven't seen it done yet. Use the high quality shims that cover the entire face, not just the washers.
    will get my mate to make a full shim from stainless
    mmm
    If you are using a rear hub you will stilll have a 10mm axle trying to fit into a 9mm dropout. Sometimes the tolerences on dropouts are such that this will work. If not you either have to turn down the ends of the axle or open up the dropouts a bit.
    aka bOb
    Reputation: bdundee's Avatar
    Why shim the rotor rotor out? I believe the Snowpack fork uses I.S. mounting so you could just shim the I.S. adapter out 5mm. I'm running a Surly hub on my Fatback fork and the 10mm axle fits fine with the adapter shimmed out.
    Quote Originally Posted by bdundee View Post
    The Snowpack is post mount.
    I think a bit of head scratching is in order then, but it doesnt sound impossible
    having being into custom motorbikes fro a while Im used to getting things made to fit !
    although its a shame things cannot be made with better compatability in mind
    A 5 mm shim under the rotor will work fine.
    I just checked the dropouts on my Snowpack fork. They are 10 mm, and an XT rear hub drops in just fine. They probably oversized them on purpose with the idea of being able to fit both 9 mm and 10 mm front axles.
    aka bOb
    Quote Originally Posted by Andy FitzGibbon View Post
    My bad, their website says they are ISO.
    So it does... though they are definitely post mount. I emailed them to let them know about the mistake.
  1. Fork question for my Hi-Fi pro
    By Rugby Chuck in forum Gary Fisher
    Last Post: 10-01-2010, 01:24 PM
  2. XC Fork Question (total newbie question...)
    By Pas de Dopage in forum Shocks and Suspension
    Last Post: 01-16-2010, 12:26 PM
  3. Replies: 22
    Last Post: 10-01-2008, 09:34 AM
  4. Stp fork question and rear wheel question=2 questions
    By Mountain biker 41 in forum Urban/DJ/Park
    Last Post: 08-25-2008, 08:14 PM
