Smallest Tube for a 26 x 4 tire- Mtbr.com
Results 1 to 7 of 7
    Can I get away with a 26x2.4 tube in a 26 x 4 tire? I've seen people running 2.4 - 2.7 tubes, but the I have a tube that's labeled just 26 x 2.4.
    Rocking on a Rocky
    Reputation: RockyJo1's Avatar
    I've use 26x2.7 HD tubes from MEC with a short life, the valve tears out of the tube. Had better luck with Maxxis DH tubes 26x2.5 - 2.7" but they are just as heavy as 26x4.0 tubes.Vee Rubber is making a light fat tube.
    :thumbsup:It doesn't matter what I ride as long as I ride it Rubber Side Down●~●.
    Reputation: Wombat's Avatar
    I found new thin tubes (~26x2.1 - 26x2.5) to be fine, until you have to patch them. Then the tube stretches too much and the patches don't hold. The thicker DH tubes I've tried didn't do this.
    Tim
    Like a FirePlug
    Reputation: ErvSpanks's Avatar
    Q-tubes 2.75s, never a problem. I've run them at 2psi in 4.6 Wazia's on snow.
    Sent from my SM-G955U using Tapatalk
    Keep the Rubber Side Down
    Iíve used tubes labeled 2.4-2.6 by Sunlite.
    Dec 2018
    Have had good results with Schwalbe SV13F in winter/summer use where flatting is not going to be an issue (packed trails, etc.) At 185-200g per it was worth the risk for me.
    Reputation: kyttyra's Avatar
    Mar 2012
    I have used both Schwalbe SV13F and Onza 26 x 2.2-2.5 Freeride tubes. The latter are labeled 26 x 2.2-2.5 and the largest tire I have used them with were BFL's on 82 mm rims. I had a few flats with both, and patching was never an issue.
  1. Replies: 12
    Last Post: 11-24-2016, 01:34 PM
  2. What is the smallest/lightest 26" spare tube?
    By matw in forum Wheels and Tires
    Last Post: 07-03-2014, 03:49 AM
  3. Replies: 8
    Last Post: 04-21-2014, 06:18 PM
  4. Smallest center line radius for 3/4" tube
    By RCP FAB in forum Frame Building
    Last Post: 03-10-2012, 08:06 PM
  5. Smallest width tire for Velocity Blunt 29er rim
    By Progen in forum Wheels and Tires
    Last Post: 05-18-2011, 08:20 PM
