Results 1 to 16 of 16
    Jul 2015
    Shimano Deore disk brakes not contacting rotor correctly?
    I recently upgraded from the stock tektro novella mechanical disk brakes on my bike to Shimano Deore M615 hydraulic brakes. The brakes work better but not as good as another bike I rode with the Deore brakes. After a few rides I can see the contact patch on the rotor doesn't look right. The pad doesn't seem to be touching the lower portion of the rotor. Anyone seen this before? The contact patch for the stock tektro brakes looked fine. The pads do seem like they have a little play between the hole and the cotter pin that hold the pads. Could this be the cause? Better brake systems use a bolt instead of the cotter pin.
    Attached Thumbnails Attached Thumbnails Shimano Deore disk brakes not contacting rotor correctly?-20160616_081142a.jpg
    Shimano Deore disk brakes not contacting rotor correctly?-20160616_081228a.jpg
    since 4/10/2009
    Reputation: Harold's Avatar
    Different brake brands have pads with different surface areas. Looks like you're using your old Tektro rotors with the new Shimano calipers. I wouldn't expect the braking tracks to line up exactly.
    As long as the pads are not overhanging the outer edge of the rotor, you'll be fine. If they are, then that's a problem. The angle on your front caliper picture makes it hard to tell, but it looks like the rear caliper probably is not overhanging.
    Reputation: watts888's Avatar
    Oct 2012
    Looks like a shimming/alignment issue. What size rotors are you using? What adapter is that on the fork and if it's a 160mm rotor, did you try it without that adapter?
    On the back rotor, no idea. Unless the stock rotor isn't the right size for the shimano calipers, but to my knowledge, they should both use the same (160mm)
    "a hundred travel books isn't worth one real trip"
    Reputation: Swerny's Avatar
    Mike
    Toronto, Canada
    2017 Trek Farley 9.6
    2017 Diamondback Haanjo Trail Carbon
    2016 Scott Solace 10 Disc
    turtles make me hot
    Reputation: NYrr496's Avatar
    That adapter on the fork is too big. You either need a smaller one or no adapter.
    I like turtles
    Jul 2015
    The stock tektro rotors were replaced. The sizes are stock, 180mm in the front and 160mm in the rear.
    I originally had magura rotors but the brakes felt weaker than the other bike I rode with the standard shimano rotors. The shimano rotors were cheap so I bought a set to try. They work better than the maguras, but I think that's because there is less material at the OD of the magura rotors. I don't think this would be a problem if the pads were riding correctly on the rotors.
    These are the magura rotors I tried.
    Shimano Deore disk brakes not contacting rotor correctly?-20160616_162606a.jpg
    since 4/10/2009
    You didn't address your pads overhanging or not. I see the same wear pattern on the outer edges of the Magura rotors, too.
    blood in / blood out
    Reputation: majack's Avatar
    Make sure that the Shimano rotors are not labeled "Resin Only". If they are, you will have to use Resin pads with those rotors.
    RICOH for LIFE
    Pain is Weakness
    Jul 2015
    The pads overhang the OD a little, but I can push them down then they don't overhang. It seems like there is too much play between the hole in the pad and the cotter pin and the pads are getting pushed up.
    A friend of mine has the same bike (felt DD70) and he upgraded to the Shimano SLX with SLX rotors. His calipers come stock with a cotter pin holding the pads, but he was able to use the threaded pin from the XT brakes instead. His contact patch on the rotors looks normal.
    Jul 2015
    Quote Originally Posted by majack View Post
    The Shimano rotors are labeled resin only, but I have resin pads so were all good.
    Reputation: Misterg's Avatar
    Jul 2014
    New Deore calipers use a narrower "track width" pad than the old Deore disks. Deore are now the same as pads as SLX. I think you will be OK, just that the inner part of the disc won't get used.
    The difference between the disc rotors:
    "old" Deore/M395 etc. on left, "new" Deore / SLX on right
    Shimano Deore disk brakes not contacting rotor correctly?-dsc00845_zps649075ab.jpg
    New on top of old - you can see that with calipers matching the new disc rotor, there will be a section of the "old" rotor that will be un touched.
    Shimano Deore disk brakes not contacting rotor correctly?-dsc00846_zps576701dd.jpg
    Just make sure that your pads aren't overhanging the outer edge of the disc and wearing a 'step' in them. (I doubt they will be).
    Non resin pads are ok on 'Resin Only' discs, but the discs will wear quicker.
    Reputation: Flamingtaco's Avatar
    Mar 2012
    Cotter pin vs bolt, doesn't matter. The pads won't be in the outermost position every time you brake, so they won't wear a lip.
    I will suffer no butt-hurt fools!
    Mar 2016
    Even with bolt (pad axle) Y8JZ98010 the brake pads still move around just not as much with as with the cotter pin.
    I think Misterg explained what is happening. I didn't even think about the different widths of surface area on the rotors RT-56 vs RT-66
    Jul 2015
    Thanks for all the help guys. Didn't know there was a difference between the shimano rotors.
    I ordered a set of the pins too, hopefully I can make them fit the deore calipers.
    Jul 2015
    I installed the pad axels today. The thread is a 4mm x .7 and the hole in the caliper body was a couple thou under the tap drill size. It tapped fine by hand. There is quite a bit less play in the pads now.
    Shimano Deore disk brakes not contacting rotor correctly?-20160622_154558b.jpg
    Shimano Deore disk brakes not contacting rotor correctly?-20160622_160730b.jpg
    Mar 2012
    I haven't gotten around to getting the bolts just yet, but my Zee's are already tapped for the bolts used in the Saint's. Common sense says they are the same casting, but I figured they would have omitted tapping the Zee's. Maybe they dropped the bolt for the pin after the calipers were machined.
    Reason for swapping the pin for the bolt? Ease in removing the bolt. The pin is not a total pain, but I broke two cotters when I was installing just the front brake as I would swap between the caliper block and pads to bleed and test. Not planning on dealing with that during every service.
  1. Replies: 6
    Last Post: 05-12-2015, 03:58 PM
  2. Did i align my disk brakes correctly???
    By mtbATXmitch in forum Brake Time
    Last Post: 03-16-2015, 01:38 AM
  3. 180MM Formula rotor with Shimano Deore Brakes
    By ViltiesVance in forum Brake Time
    Last Post: 02-21-2015, 09:55 AM
  4. Replies: 0
    Last Post: 07-25-2013, 08:14 PM
  5. Tektro Novela Disk Brakes - Adjustment and bent rotor?
    By howetechnical in forum Brake Time
    Last Post: 10-20-2011, 01:31 AM
Members who have read this thread: 8
