Shaving weight on a 2013 Salsa Beargrease?- Mtbr.com
Results 1 to 24 of 24
    Does anyone have recommendations for "bang for the buck" weight loss on a nearly stock 2013 Salsa Beargrease?
    I am already tubeless and it weighs in just under 29lbs...
    I'm down to 26 lbs for my XL. The biggest drop was the Nextie rims for sure. They weigh 500 grams each and replace the holy and drilled rolling Dayrls, rim strips and tube that weighed 1440 per wheel so it's about a 2 lb of rotating weight savings PER WHEEL! Also xo carbon brakes, Niner RDO bar, to bolts, etc, etc.
    Attached Thumbnails Attached Thumbnails Shaving weight on a 2013 Salsa Beargrease?-image.jpg
    turtles make me hot
    Reputation: NYrr496's Avatar
    What's the stock crank on that bike? The new Raceface Turbine Cinch is light for the money.
    Duct tape rim strips are lighter than Surly rim strips.
    I'm pretty sure 45 North tires are lighter than most others.
    I'm not sure of the build on the BG wheels but if they're laced with Comp spokes an brass nipples, you could save 1 gram PER SPOKE switching to Supercomps. Alloy nipples are even lighter.
    I like turtles
    aka bOb
    Reputation: bdundee's Avatar
    Wheels Wheels Wheels Wheels Wheels Wheels Wheels Wheels Wheels Wheels Wheels Wheels Wheels Wheels Wheels Wheels Wheels Wheels Wheels Wheels Wheels Wheels Wheels Wheels Wheels Wheels Wheels Wheels Wheels Wheels Wheels Wheels Wheels Wheels Wheels Wheels Wheels Wheels Wheels Wheels Wheels Wheels Wheels Wheels Wheels Wheels Wheels Wheels Wheels Wheels Wheels Wheels Wheels Wheels Wheels Wheels Wheels Wheels Wheels Wheels Wheels Wheels Wheels Wheels Wheels Wheels Wheels Wheels Wheels Wheels Wheels Wheels Wheels Wheels Wheels Wheels Wheels Wheels Wheels Wheels Wheels Wheels Wheels Wheels Wheels Wheels Wheels Wheels Wheels Wheels Wheels Wheels Wheels Wheels Wheels Wheels Wheels Wheels Wheels Wheels Wheels Wheels Wheels Wheels Wheels Wheels Wheels Wheels Wheels Wheels Wheels Wheels Wheels Wheels Wheels Wheels Wheels Wheels Wheels Wheels Wheels Wheels Wheels Wheels Wheels Wheels Wheels Wheels Wheels Wheels Wheels Wheels Wheels Wheels Wheels Wheels Wheels Wheels Wheels Wheels
    Lone Wolf
    Reputation: Osco's Avatar
    Apr 2013
    ok so,,, wheels,,, ok,,,,,, LOL
    “I seek only the Flow”,
    Climbing Is Supposed To Be Hard,
    Shut Up Legs :P
    That's a huge weight savings on the wheelset. What do those Nexties cost?
    Quote Originally Posted by NYrr496 View Post
    If you ride in snow, DO NOT get alloy nipples.
    Quote Originally Posted by bunger View Post
    Nextie Bike | Carbon Bicycle Devotion | Online Shopping
    turtles make me hot
    Quote Originally Posted by jonshonda View Post
    I ride my bikes year round... Snow, beach, whatever.
    My 29er had a set of wheels I built 5 years ago. I used black brass nipples. They were all white and chalky and when I tried to remove them, they were all brittle and some of them broke.
    On my fatty, I have alloy nipples on the front wheel and brass on the rear. The black finish on the front nipples is still shiny and clean, where the rear ones are already getting ugly.
    It may just be a fact of life, since these bikes get ridden in adverse conditions, they may need a little more wheel maintenance. Maybe even a relacing every few years.
    I build lots of fat wheels and sometimes people are concerned with weight and sometimes they want bling but many of the wheels I build get alloy nipples.
    I like turtles
    Wig
    Wig is offline
    Aug 2014
    I shaved almost a pound by switching out the bars, stem and seat post. With Sarma rims I'm right at 24lbs
    since 4/10/2009
    Reputation: Harold's Avatar
    I, too, have seen both types of nipples corrode. I have seen it happen on bikes ridden only in fair weather and kept in the house (not the garage, shed, or basement). I have seen bikes ridden in the nastiest conditions not have any problems with nipple corrosion.
    I think there are more factors at play here than just nipple material.
    Unfortunately, I think it's going to take some pretty deep pockets to run a good test to pinpoint the variables at play here.
    aka bOb
    I like nipples.
    turtles make me hot
    They're one of my favorites.
    I like turtles
    Oct 2014
    When you say "allow nipples" does that refer to some very specific alloy? Brass is an alloy too so all this nipple talk seems a bit ambiguous to me.
    turtles make me hot
    Quote Originally Posted by Sgraffite View Post
    When I say alloy, I mean aluminum. Sorry.
    I like turtles
    From now on, let's allow nipples.
    since 4/10/2009
    generally speaking, when people refer to alloy nips, they're talking about aluminum alloy. Brass is a very specific alloy that is self explanatory.
    Quote Originally Posted by sisu View Post
    Pictures or it didn't happen.
    Latitude 61
    turtles make me hot
    Quote Originally Posted by sryanak View Post
    Do NOT test me.
    I like turtles
    Wow! That's pretty significant savings! What did you put in for the bar, stem, and seat post?
    nvphatty
    Guest
    Quote Originally Posted by bdundee View Post
    I like nipples.
    yes! yes indeed with or without rings
    aka bOb
    One could always sand the plastic down in some not so vital areas
    Shaving it should drop some weight too.
    Reputation: smthgfshy's Avatar
    Sorry to derail the previous 15 replys....but,
    I found the biggest bang for buck to be in the 1)brake rotors & seatpost clamp 2)brakes, 3)cockpit, chain, pedals, & saddle and 4)crank. I brought my alum, medium, 907 w/70mm alum rims down from 28.75lbs to 26lbs by swapping out parts in that order.
    For example, I switched from BB7's & avid rotors to formula hydro's and Ashima rotors and saved 1.5lbs. Atlas crank to turbine crank saved .25lbs, pedals/chain/saddle/cockpit saved 1 lb. Another part worth mentioning is your headset. The CK or CC110 series weigh considerably more than the CC40 or cheaper options. Switching to carbon 80mm rims, lighter hubs/spokes, and a carbon crank would maybe cut another 1.5lbs for ~$1500. I learned that those big ticket parts should be bought when you build it, not added later as an upgrade. ok, now back to your regularly scheduled nipples....good luck!!
  1. Replies: 0
    Last Post: 11-04-2013, 09:42 PM
  2. 2013 Salsa Beargrease obsolete?
    By FrY10cK in forum Fat bikes
    Last Post: 07-04-2013, 11:11 AM
  3. PAID SPAM-F/S 2013 Salsa Beargrease frame only
    By NOBBY605 in forum Fat bikes
    Last Post: 05-09-2013, 05:23 AM
  4. 2013 Salsa Beargrease--Ridden
    By lawfarm in forum Fat bikes
    Last Post: 12-06-2012, 05:42 AM
  5. 2013 Salsa Beargrease Racing Fatty :-)
    By Sevenz in forum Fat bikes
    Last Post: 08-24-2012, 05:26 AM
