semi fat bike- Mtbr.com
Results 1 to 16 of 16
Thread: semi fat bike
    semi fat bike
    hey guys
    i have a vicious cycles thunderwing and i love it just a bit heavy for a cross ****ry rides i have plans to build a hardtail whit a 26 by 3 inches tires can you guys help me whit some sugestions maybe the lightest in this size thankas in advance and hello from mexico....
    Reputation: masterofnone's Avatar
    Surly makes several models that will fit fatter rubber without going the full fat route. Check out the kona unit, mine fits a 2.7 on a large marge rim in the rear, pretty damn close.
    Reputation: Velobike's Avatar
    Not worth doing if you have to spend money to do it. Best to spend the money going full fat unless you have the parts lying around or available cheap.
    You'll end up with an almost but nowhere near fat bike. There's a huge difference in flotation between a 3" tyre and a 4" one.
    The Surly 1X1 will take a 3" rear.
    Latitude: 5736' Highlands, Scotland
    Reputation: bikeny's Avatar
    As others have said, it's probably not worth doing. But if you are set on this, many 29er frames will take a 26x3" tire. Also, there were very few 3" tires available, and I believe none are in production anymore. The ones that were available were DH tires and weigh just as much as a proper fatbike tire. Another option was the WTB Timberwolf Race 26x2.7 tire, also no longer in production, but much lighter than the 3" tires.
    If you really want some fat rubber, I just happen to have some 3" tires for sale in the classifieds, go to the tire section!
    That Unicycle Guy
    3" tires are generally heavier than the current 3.7-4.8 tires available. If you want a lighter weight almost fat tire I would look at the Bull Lock or Black Panther at Jenson. Not 3" by any means but much larger than they say and spread out nicely on wider rims besides being way lighter.
    Reputation: MikenIke's Avatar
    May 2013
    This thread lives again with the Surly Instigator.
    Didn't care for the Instigator build so went my own way. Surly Troll 1x9 with 650b White Bros 110mm fork and Velocity Dually wheels wrapped in 26x 2.8" Bontrager rubber. Trollstigator. Brings a smooth-ass ride.
    Any one else on Semi Fat? What's your build?
    turtles make me hot
    Reputation: NYrr496's Avatar
    The Instigator is my son's next ride once he's tall enough.
    I like turtles
    Reputation: seat_boy's Avatar
    How about some pics?
    Quote Originally Posted by MikenIke View Post
    http://www.bikingtoplay.blogspot.com/
    RIGID, not "ridged" or "ridgid"
    PEDAL, not "peddle." Unless you're selling stuff
    I will get a Jones...
    Aug 2013
    Budget Semi Fat Build, dude figured out some cool stuff on the cheap
    Building a Fat Tire Touring, Trekking, Commuter Bike, by Rideon - Bike Tourings
    Quote Originally Posted by cwcheung View Post
    May 2013
    Quote Originally Posted by seat_boy View Post
    Here's the first ride pic.
    Biketourings, I read your blog where put a 24x2.6 on the rear, what's the biggest 26" tire you think it would hold.
    Just ride.
    Reputation: Lothar Othp's Avatar
    Jun 2005
    Fat Sawyer
    Trek Sawyer with custom machined rear dropouts to gain the little bit of extra clearance needed to mount 29 x 3" Surly Knards.
    I have a Kona unit with a Krampus Fork and a Knard on a rabbit hole rim. P35 Blunt in the rear with a Conti. 2.4 King somethin somthin? It's getting salsa cross drops next. Semi fat
    Aug 2013
    Re: Bike Tourings read your blog, Widest 26"tire to fit
    Small Block Eight 2.35 fits with comfortable clearance, maybe a 2.4 without heavy tread, Kenda K Rad or Maxxis Holy Roller for example, possibly Schwalbe Big Apple 2.5 but they would probably have limited clearance and less grip. Maxxis Larsen 2.35 would be fun too. Have considered Slant Six 2.5 for front, might not clear on rear wheel,would be fun to try though.semi fat bike-1661928_orig.jpg
    Oct 2015
    Quote Originally Posted by Lothar Othp View Post
    Where did you get the custom dropouts? I would like some.
  1. Semi fat bike?
    By GR_Russia in forum Fat bikes
    Last Post: 10-30-2010, 02:23 AM
  2. Okay, here it is: my semi-WW bike @ 23.19lbs!
    By djork in forum Weight Weenies
    Last Post: 01-24-2009, 11:46 PM
  3. Semi cheap AM bike
    By mtnbikerride in forum All Mountain
    Last Post: 12-23-2007, 09:02 PM
  4. Semi OT - Other uses for bike lights
    By JohnnyTooBad in forum Riding Passion
    Last Post: 09-26-2006, 08:32 AM
  5. Semi New Bike Porn
    By Ivan the Terrible in forum Downhill - Freeride
    Last Post: 06-06-2005, 06:42 AM
