Salsa MUKLUK GNARWHAL 27,5х4,5- Mtbr.com
Results 1 to 10 of 10
    Jan 2019
    Hello everyone.
    Has anyone here inserted the wheel 27.5 x4.5 in Salsa MUKLUK 2018?
    I would like to see photos and read your reviews about the gaps between the tire and the frame.
    Thank you all in advance for the quick answers.
    Only a test fit, didn't ride it.
    Jan 2019
    Thank you very much. What is the position of the rear axle? Front or back position?
    Do you think that on the aluminum frame the distance from the frame to the tire will be more or less?
    This was a year ago, zoom in and maybe you can see the position, I don't remember, looks like it was all the way forward. Take your bike to a shop with a case of beer and do a test fit.
    Reputation: calzonical's Avatar
    Aug 2005
    I have 27.5 x 4.5 Gnars studded on Jackalopes on 2017 Aluminum Mukluk. I run the dropouts about 3 millimeters out from being slammed forward and there is about 3/8 of an inch clearance at Seat Tube and plenty of room at chain stay and seat stay junctions and plenty of side clearance as well. Rear tire pressure 7psi and less.
    I have tried and failed to mount the rear tire at 20psi in the same position. The ridiculously high psi made the tire far too tall and wide, but would fit by moving dropouts back.
    Added photos with dropouts slammed forward and tire at 6.5psi and 111.5mm in width @ 7680' in elevation:
    Chain stay junction clearance
    Seat Stay junction clearance
    Clearance with Chain on 42T
    Clearance at Seat tube
    Jan 2019
    Please show me a photos?
    Jan 2019
    Thanks so much. Position dropouts-front or rear?
    Aug 2005
    Quote Originally Posted by KonstantinSPb View Post
    pictures provided above have dropout pushed to the front
    Jan 2019
    Thanks,
    Then I have a question - why even with such small ground clearance no one pushes the wheel back? Clearances are really very small, I would increase them by moving the axis backwards.
    Aug 2005
    Thanks,
    no one is saying YOU can't push the wheel back to suit your needs.
  1. Mukluk vs Mukluk 2 vs Mukluk 3 FRAME?
    By bikeny in forum Fat bikes
    Last Post: 12-28-2017, 07:59 PM
  2. Bontrager Gnarwhal TLR - 27.5 studded tire review
    By the_eleven in forum Fat bikes
    Last Post: 11-01-2017, 04:43 PM
  3. Replies: 67
    Last Post: 06-29-2017, 04:11 PM
  4. Dry snow, Gnarwhal, bud and Lou and you
    By Dash1001 in forum Fat bikes
    Last Post: 04-16-2017, 09:43 PM
  5. Gnarwhal
    By solarplex in forum Fat bikes
    Last Post: 08-09-2015, 11:18 PM
Members who have read this thread: 14
