salsa mukluk with 120 tpi nate and self drilled rolling daryl hates tubeless- Mtbr.com
Results 1 to 12 of 12
    Jun 2010
    So I have a problem, Before I moved to Korea I set up my Muk tubeless, I have 120 tpi Nates and Rolling Darryls. The front tire has been great no leaks what so ever. Happy with that But the back on the other hand has had problems. I was riding around on the trail and I kept hearing hissing on and off and in like 20 miles had to reinflate my rear tire like 3 times. I filled up my tire to like 15 than took off to keep riding, 1 min on trail rode over a root and bam tire pops off rim very loudly. Koreans were jumping on the ground. Now I'm sitting here or in Korea with a regular tube in my fatty and I want to set it back up tubeless again but am not sure how to without leaks. I have Stans in the tires already and have gorrilla tape wrapped around it. I don't have access to a compressor but do have a joe blow mountain pump. Its also hard to get ahold of stuff like window seal stuff. If I wrap the rim in a bunch of gorilla tape will it work better. Help with this sitch please.
    Reputation: tunadawg's Avatar
    Sep 2012
    That worked for me. I used clear 3m duct tape instead. I split the tape and just wrapped two more times over the bead shelf. Cured my problem
    You could always go ghetto tubeless.
    Oh noes. I'm going to drink the Kool-Aid.
    Jun 2010
    Please explain ghetto Tubeless
    Try your googler. It works. Trust me. When in doubt just add 'mtbr' to yer query. Simple as that. Just like ghetto tubeless.
    Hybrid Leftys aren't real Moderator
    Feb 2005
    Split tube = no leaky hassles, at least from anything other than the tire itself.
    Sucks, sorry to hear you have a hassle in a far off, less fat supportive land....
    This is a Pugs not some carbon wannabee pretzel wagon!!
    - FrostyStruthers
    www.mendoncyclesmith.com
    Jun 2010
    Mine leaks from where the tire meets the side of rim
    Feb 2005
    Quote Originally Posted by ridehard84 View Post
    In that case, not to be a zealot, but split tube would resolve that, pretty much guaranteed.
    Hey, at least it's a cheap answer!
    - FrostyStruthers
    All fat, all the time.
    Reputation: Shark's Avatar
    Feb 2006
    Yep, when my gorilla tape started to be finicky, I switched to split-tube and for the most part it holds air better especially around the bead.
    That being said, you can always try a second wrap of tape....I had to do that on one of my RD rims.
    Jun 2010
    So split tube sounds good than less leaking. So do like a 24x2.1tube
    Reputation: awai04's Avatar
    Will ghetto tubeless prevent the tire from coming off of the rim? Not on a fat bike, but on a 'regular' mtb, I once had a new tire that kept blowing off the rim. The problem turned out to be a problem with the tire bead, not the rim setup.
    Feb 2006
    With a wide rim like the rd, probably a 24x 2.3 - 2.75 would give you more rubber to work with if you can find one.
  1. Replies: 1
    Last Post: 02-01-2015, 12:35 PM
  2. Surly rolling daryl on Hope Fatsno
    By HDTVdevil in forum Wheels and Tires
    Last Post: 07-26-2014, 08:40 AM
  3. Rolling Darryl/Nate vs. Marge Lite/Nate
    By Chilly H2O in forum Fat bikes
    Last Post: 01-11-2014, 06:36 AM
  4. Surly Tim strips on rolling Daryl
    By Geist262 in forum Fat bikes
    Last Post: 12-06-2011, 06:40 AM
  5. Drilled Rolling Daryl/Clownshoe rim on dirt
    By SSBonty in forum Fat bikes
    Last Post: 10-19-2011, 12:06 AM
