Salsa Cycles "Enabler" Fat Front Fork- Mtbr.com
Results 1 to 15 of 15
    Harmonius Wrench
    Reputation: Guitar Ted's Avatar
    This was seen at Interbike, but it appears it is on its way to reality. (Pic courtesy of Salsa's Facebook page)
    Attached Thumbnails Attached Thumbnails Salsa Cycles "Enabler" Fat Front Fork-13836_161133646701_150815291701_2638087_6819698_n.jpg
    Riden' an Smilin'
    Guitar Ted
    Blog
    RidingGravel.com
    Self-defeatist
    Reputation: CLONG's Avatar
    Nov 2006
    Sexy. Great name.
    Looks like...135mm?
    I'm covered in beer.
    Harmonius Wrench
    Quote Originally Posted by CLONG
    Sexy. Great name.
    Looks like...135mm?
    Yep. 135mm, two water bottle mounts, ala the Fargo, and stainless forward facing drop outs.
    It looked suspension corrected to my eyes when I handled it at Interbike.
    Riden' an Smilin'
    Guitar Ted
    Blog
    RidingGravel.com
    If only I could make my 100mm dynamo hub fit 135mm.
    Reputation: coastkid71's Avatar
    good idea with the bottle mounts,if your already running a fork and want to add bottle mounts just use part of the heavy plastic brackets for reflectors that come on new bikes,my LBS had lots of them kicking about,work a treat, cost nothing
    " width="549">
    " width="549">
    plan it...build it....ride it...love it....
    http://coastkid.blogspot.com/
    Quote Originally Posted by Guitar Ted
    So no go on the Fargo?
    Harmonius Wrench
    Quote Originally Posted by sanjuanswan
    Not unless there is a shorter axle to crown one in the works.
    Riden' an Smilin'
    Guitar Ted
    Blog
    RidingGravel.com
    Team Captain
    Pusley fork?
    Ride = Life
    Reputation: racerxti's Avatar
    Quote Originally Posted by coastkid71
    " width="549">
    " width="549">
    Ok now I'm impressed.
    Riding 2.5 hours home 1000 elevation gain was a pain with only two bottles. I need 3+ to keep it safe. I'm going to build these this week.
    I wanted fork mounted water bottle mounts for my commuter bike, ala Salsa Fargo. This will do the trick.
    "Riding is about rhythm and flow. It's the wind in your face and the challenge of hammering up a long hillÖ" - Gary Klein
    Harmonius Wrench
    Quote Originally Posted by ScaryJerry
    Pusley fork?
    17mm offset one wouldn't be ideal. Speaking of offset, the fork offset is only 43mm. Fargos have a minimum offset of 50mm. (55mm on sizes Large and smaller) You'd be getting major toe overlap with a Pugsley fork. The axle to crown is a smidge higher on the Pugsley too, but that isn't the big issue here. The offset is just all wrong for a Fargo running a Pugsley fork.
    Riden' an Smilin'
    Guitar Ted
    Blog
    RidingGravel.com
    Birthday Collector
    Reputation: ATBScott's Avatar
    Careful with those plastic clips - they can get a bit brittle after some exposure to sun, or when it gets cold. They are designed to hold a one ounce reflector, not a 28-ounce bottle! A bottle into the front wheel at any significant speed could be catastrophic!
    R.I.P. Corky 10/97-4/09
    Disclaimer: I sell and repair bikes for a living
    Reputation: spacemonkey's Avatar
    Two more shots liberated from the Salsa Facebook page
    Attached Thumbnails Attached Thumbnails Salsa Cycles "Enabler" Fat Front Fork-salsa-enabler-glamour-shot-.jpg
    Harmonius Wrench
    Salsa Speaks!!
    Thought you fat bike freaks would appreciate this. Jason Boucher, head honch of Salsa Cycles, posted this comment on Twenty Nine Inches regarding the Enabler Fork:
    Hey folks, Butcher from Salsa here.
    Just wanted to say thanks for all the interest in the ďEnablerĒ. Itís a pretty neat product that is clearly in the prototype phase. Because it is in the prototype phase, we canít answer some of the questions. We can tell you a few of the ideas around this fork.
    It is obviously Surly Endomorph compatible and aimed at 29ers. With the coming of Surlyís new Larry tire there is new opportunity for a fork like this. Sure a suspension fork and standard 29er wheel may be lighter. Who cares? That set up simply canít give you the float and in some cases the fun that you can have with a fork & wheel set up like this.
    2 years ago, I rode my El Mariachi this way for the winter.. It worked pretty good. No, not snow bike good, but good enough for me to ride more stuff with a bike I already own. What I found out then is that generally speaking the rear wheel follows the front and short of breaking trail I had more overall float and ability than on my comparibly equipped standard 29er front wheeled bike. Again, this set up canít compare to a snow bike. It can however, give you an option if you canít afford a specialty snow bike. Itís an eye opener for sure.
    Regarding the fork and brake set up. This specific fork works with standard rear hubs and a front brake. It is a prototype and certainly could change if needed
    Riden' an Smilin'
    Guitar Ted
    Blog
    RidingGravel.com
    Ride = Life
    hmmm a Salsa Fat Fargo sounds like a pretty cool bike.
    Team Captain
    Quote Originally Posted by racerxti
    I'd buy it in a hot minute.
