RWC 30mm Fat Bike Bottom Bracket 100mm bb questions- Mtbr.com
Results 1 to 6 of 6
    Trying to be helpful
    Reputation: Guy.Ford's Avatar
    Ordered my RWC 30mm fat bike bottom bracket today to go on my Mayor (100mm BB) to replace the creaky AF Race Face unit that came installed with my RF Turbine Cinch crankset. Parts should be here Monday. Just wondering if there is anything I need to know about the install that isn't going to be straightforward?
    I've read others mention the RWC cups are narrower, so it has to be spaced slightly different than the stock RF unit, but nobody ever clarified in any thread I read what that meant. If anyone has any insight that might prove useful, I'd greatly appreciate it. I really just want this to go smoothly and get back to riding without much hassle ASAP.
    I have all the tools needed, also purchased some .5mm 30mm spindle spacers, JIC.
    #THELEGENDMTB
    2016 RSD Mayor
    2018 Diamondback Release 5C
    2017 Diamondback Haanjo Trail
    since 4/10/2009
    Reputation: Harold's Avatar
    Not sure which flavor of this bb you bought, as you didn't specify.
    I got the RWC BB86/92 to 30mm one, and it's the same width as the RF one it replaced. Flanged bearings press straight into the frame.
    Did you get the BSA (threaded) one? If so, I hear it is a touch narrower, also. The extra spindle spacers should be just the ticket to allow you go get it spaced correctly.
    If its a threaded BB I would have a good shop chase and face the bottom bracket. I do this on all my bikes to help reduce issues from manufacturing tolerance. Grease the threads really well, even use plumbers tape if creaking still persists after install.
    Yeah sorry it's the external 30mm as seen here http://enduroforkseals.com/id431.html
    Sent from my SM-G935T using Tapatalk
    #THELEGENDMTB
    2016 RSD Mayor
    Rocking on a Rocky
    Reputation: RockyJo1's Avatar
    The kit says it's got spacers. You could have just ordered the bearings and used the RF cups.
    It doesn't matter what I ride as long as I ride it Rubber Side Down●~●.
    Quote Originally Posted by RockyJo1 View Post
    I could have, but for the price of bearings and bearing puller/installer it was cheaper to order a complete bottom bracket. Also I can always keep the current cups and eventually install new bearings later when it's more cost effective. Appreciate the suggestion though.
    #THELEGENDMTB
    2016 RSD Mayor
  1. Replies: 4
    Last Post: 03-04-2016, 08:29 AM
  2. RaceFace Cinch cranks w/ Hope 30mm bottom bracket
    By CWnSWCO in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 10-07-2015, 10:31 AM
  3. Threaded bottom bracket for 30mm spindle other than race face
    By dhracer1067 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 04-13-2015, 12:06 AM
  4. In search of Race Face BB92 30mm Bottom Bracket or compatible BB
    By tonyvt in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 04-11-2015, 06:40 PM
  5. 7005 100mm Bottom Bracket
    By todwil in forum Frame Building
    Last Post: 04-23-2014, 07:01 AM
