Rim width and pressures (50 vs 65mm on SC32)- Mtbr.com
Results 1 to 5 of 5
    I run an SC32 with a 50mm rim and a Larry - I went for the 50mm as the advice was I wouldn't get any rubbing issues, however I am missing the lower pressures I can run on the rear (80mm) rim.
    It seems 65/70mm is the widest rim one can run, how lower can one go pressure wise with that? It's no just snow/sand riding, there'll be trails too, though not DH or too aggressive.
    One benefit of the 50mm rim is I can just about run a regular 2.3 tyre if I want to (though I've not done so yet)
    bigger than you.
    Reputation: Gigantic's Avatar
    I vary my pressures with the conditions. In snow, 3-4 psi; soft dirt and wet roots, 8-9; hardpack, 12-14 psi.
    All fat, all the time.
    Reputation: Shark's Avatar
    Feb 2006
    Huh?
    I ran a rolling Darryl in my sc32....
    It was damn close though ..... Did lose some anodizing on the inside fork legs
    That's my point shark!
    Reputation: Welnic's Avatar
    Feb 2013
    I have HuDu/Knard on Marge Lites, and I run the same pressures as Gigantic. On sand instead of snow, though.
  1. Replies: 8
    Last Post: 10-22-2017, 07:27 AM
  2. Which 65mm rim to get?
    By OfficerFriendly in forum Fat bikes
    Last Post: 10-04-2014, 06:27 AM
  3. Replies: 13
    Last Post: 08-11-2014, 09:42 AM
  4. Replies: 3
    Last Post: 04-22-2014, 11:28 PM
  5. Larry on a 65mm vs 82 mm rim
    By thecanoe in forum Fat bikes
    Last Post: 12-22-2013, 04:38 PM
