rim width effect on tire width- Mtbr.com
Results 1 to 8 of 8
    Mar 2006
    I searched but couldn't find any info.
    I am currently running a Surly Lou on a 80mm Mulefut. I really want to go to a 100mm rim, but I'm also very very tight clearance wise.
    So curious if anyone can say for sure how much my Lou will widen with that wider rim?
    Thanks!!!
    Reputation: CanuckMountainMan's Avatar
    Oct 2018
    My mad math skillz predict about +10mm per side
    ...but my gut tells me it will be about half of that.
    It's been a while.....but it was around 8mm difference on a well stretched Lou
    Mar 2006
    Found the info on Surly's website, Looks like a Lou grows 7-8mm going from an 80mm to a 100mm rim.
    Thanks Everybody.
    This place needs an enema
    Reputation: mikesee's Avatar
    Aug 2003
    Quote Originally Posted by wookieone View Post
    Thanks Everybody.
    jefe -- ping me before you move forward. might have something for you.
    Reputation: BlueCheesehead's Avatar
    One way to estimate it: The cross section of a tire is roughly a circle. Think of the rim width as being part of the circumference. With diameter = circumference / pi, one could expect the diameter to change roughly by (100-80)/pi, so around 6.4mm. Now the rim really acts as a chord and not part of the circumference so one should expect the diameter to grow more than the perfect circle formula would suggest. Adding 1-2mm seems prudent and voila, you are at the 7-8mm Surly suggests. Divide by two for clearance lost on each side. Again, a tire cross section is not a perfect circle, so that results in but an estimate.
    Reputation: Dilligaff's Avatar
    Nov 2015
    A friend runs the FBR on his 80mm Turnagain rim and I run the same tire on my 100mm Turnagain rim. His tire measures 4.442" and mine measures 4.585", which is a difference of 0.143", or 3.63mm. We are the same weight and there have been times I stayed afloat and he sank in the snow.
    Nothing to see here, move along folks.
    Rippin da fAt
    Reputation: BansheeRune's Avatar
    Thanks!!!
    What is the clearance with your current setup?
    My Bud/Lou gained 5-6mm in width going from 80's to 100's. The notable difference is in the radius of the crown of the tire and how the tires ride and feel.
    Get fAt, Stay fAt, Ride fAt
    Doctor recommended...
  1. Replies: 3
    Last Post: 12-07-2018, 03:36 AM
  2. How much does rim width effect tire?
    By hankscorpio in forum Wheels and Tires
    Last Post: 09-17-2015, 06:43 AM
  3. effect of rim width on rim strikes
    By mccarthy in forum Fat bikes
    Last Post: 08-03-2015, 12:57 PM
  4. Replies: 3
    Last Post: 04-22-2014, 11:28 PM
  5. Effect of rim width on tire footprint and traction
    By artnshel in forum Wheels and Tires
    Last Post: 07-15-2004, 08:05 AM
