Removing Studs for Summer Use- Mtbr.com
Results 1 to 17 of 17
    Nov 2008
    I bought my first pair of studded fat tires this winter, Terrene Cake Eaters 26x4.6. Been a great winter tire in the midwest were we usually only get a few inches with icy batches in between. I really like the Cake Eater tires so was considering removing the studs and running them for summer use then putting studs back in for winter. Will the stud pockets get jammed with dirt and rocks making it impossible to put the studs back in? Trying to decide if swapping fat tubeless tires is more of a PITA than destudding/studding.
    Hybrid Leftys aren't real Moderator
    Feb 2005
    Quote Originally Posted by Sasquatch1413 View Post
    10 minutes with a compressor vs two hours of mindless drudgery and carpal tunnel.
    I'll let you figure that out the risk/benefit analysis.....
    This is a Pugs not some carbon wannabee pretzel wagon!!
    - FrostyStruthers
    www.mendoncyclesmith.com
    And before you put the studs back in next winter, you have to dig out all of the rock bits and dirt that have wedged into the stud pockets. Yes did it once; done with that.
    Rocking on a Rocky
    Reputation: RockyJo1's Avatar
    Turn them inside out.
    :thumbsup:It doesn't matter what I ride as long as I ride it Rubber Side Down●~●.
    Rocking on a Rocky
    But seriously it is a softer rubber it will not last long in the dirt.
    Reputation: BlueCheesehead's Avatar
    Yes, studs can be reinserted, but it's a pain in the butt. This is not something you are going to want to do every year. You will be much happier buying a second set of tires...better yet, if you can find a second wheelset get that too. Being able to quickly swap from studded to unstudded is a nice option in the shoulder seasons.
    EAT MORE GRIME
    Reputation: 127.0.0.1's Avatar
    Nov 2013
    Quote Originally Posted by RockyJo1 View Post
    /thread. you win, take the rest of the day off on us
    "Put your seatbelt back on or get out and sit in the middle of that circle of death." - Johnny Scoot
    Nov 2008
    I've always heard removing/installing studs are a PITA but I've never tried it myself, and sounds like I never will Thanks for the input. Gonna grab a pair of Jumbo Jims for summer riding and swap em out.
    Sep 2014
    If anyone is ever absolutely determined to unstud/restud their tires for summer/winter use, these are an option to keep the pockets nice and tidy...
    https://bikestud.com/collections/stu...ire-stud-plugs
    Reputation: solarplex's Avatar
    Apr 2014
    Biggest thing i found was the aluminum around the tip like mushrooms and jambs in the tool.
    I would just look for some cheap summers. Anything works in the dirt really... just need something that has not alot of self steer.
    Fatbike, XC bike, Gravel Bike....
    Quote Originally Posted by MaximumX View Post
    So I could add Remove, Insert, Remove, Insert to my annual work load. Cool!
    Crazy on this ship of fools...
    A fool and his money are soon parted.
    Reputation: CanuckMountainMan's Avatar
    Oct 2018
    I studded my Gnarwhals (Farley 7) last Fall, I am so NOT going through that again anytime soon, lol
    ...and purchased a pair of Barbegazi's right after (20% off sale) even though I won't need them until Spring.
    Still looking for a second set of wheels to run tubeless with the Barbs, but 27.5 Carbon hoops are NOT cheap in Canada.
    I can pick up a second pair of new takeoff matching MuleFut 80's for 1/4 of the price locally. Think I'll just roll with those.
    All fat, all the time.
    Reputation: Shark's Avatar
    Feb 2006
    Buy a summer set of tires! Even used if you are trying to save$$.
    Seems like putting those in and then taking them out would be way more work than cleaning some dirt and tiny pebbles out of the pockets.
    Latitude 61
    Quote Originally Posted by CanuckMountainMan View Post
    ... Carbon hoops are NOT cheap in Canada. ...
    Dat's nuth'n dat. Eh? Get yur axe and cut & heat some PVC over the fire, Porky quills & sap for spokes and Bob's your uncle.
    Unbelievable some of the prices here. I'm lucky in that I have an LBS that can usually get me anything within a week, sometimes two, and almost always for less, often meaningfully less, than if I order it myself online directly from the States. Even compared to if I order it shipped to just across the border in the States and drive down and bring it across myself.
    Reputation: veloborealis's Avatar
    Back when I lived in the Great White North, once I took the time to stud a set of tires, those became my winter tires.
    Buy another set for summer use. The good news is you can go narrower, and maybe lighter, with a tread pattern more suited for multiple surfaces.
    Veni vidi velo!
  1. Replies: 82
    Last Post: 11-28-2015, 10:19 PM
  2. Removing cantilever studs
    By hozzerr1 in forum Singlespeed
    Last Post: 02-02-2015, 01:27 PM
  3. Removing cantilever studs
    By hozzerr1 in forum Cyclocross
    Last Post: 01-30-2015, 03:40 PM
  4. Removing Monocog brake studs?
    By AmericanTemplar in forum Brake Time
    Last Post: 06-20-2013, 08:26 AM
  5. removing vbrake studs from 02 Z1?
    By bayarearider in forum Shocks and Suspension
    Last Post: 10-26-2004, 09:13 AM
Members who have read this thread: 95
