Removing Front Derailleur on GBEM w. Shimano Alivio fd-m410e- Mtbr.com
    n3g
    n3g is offline
    Mar 2019
    So there are 2 "notches" in the BB housing that the FD lock into I am setting this (2015 Gravity Bullseye Monster) up as a 1x and have had a water issue in the BB and want to seal off these notches when removing the FD. Has anyone else had this issue? If so how did you resolve it?
    Attached Thumbnails Attached Thumbnails Removing Front Derailleur on GBEM w. Shimano Alivio  fd-m410e-received_430776510827670.jpg
    Removing Front Derailleur on GBEM w. Shimano Alivio  fd-m410e-received_2127257404055334.jpg
    Reputation: BlueCheesehead's Avatar
    The bottom bracket cup threads extend well past the notches. Grease them up good and it should help seal it up. That said, water can get to to bottom bracket from various areas, seat tube, head tube, bottle cage bolt holes and etc. Sometimes it's best to understand that water will get in there, and give it an easy means to get out. You might consider a weep hole (or not if your riding submerges your BB).
    n3g
    n3g is offline
    Mar 2019
    Thank you for the insight. I will just go with a 2.5mm spacer to replace the space on the FD bracket and run it. I can always pull it apart once a month and clean her up.
    since 4/10/2009
    Reputation: Harold's Avatar
    looks like you need to hit your frame with some frame saver or similar protectant
  1. Removing or covering gear indicator on Alivio
    By JonathanGennick in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 05-14-2015, 05:39 AM
  2. Advice on swapping front derailleur from Alivio to Deore - Trance X4
    By screwynewy in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 01-13-2014, 05:27 AM
  3. Removing Alivio FC-M430 crankarm
    By joshhan in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 12-13-2012, 09:03 PM
  4. Removing Shimano Alivio Crankset
    By knucklesandwich in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 12-17-2006, 03:11 PM
  5. EF-29 shifters with Deore rear drailleur and Alivio front derailleur?
    By zenrad in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 06-23-2004, 07:22 PM
Members who have read this thread: 25
