Rear triangle to crank arm clearance- Mtbr.com
Results 1 to 2 of 2
    So I just received my gravity deadeye single speed Fat bike. ( I know budget bike). And got everything greased properly and torqued. I noticed that the crank on my drive side is 5mm away from the triangle and 11mm on the non drive side. I did a few measurements and it seems centered with the down tube and the bb, it seems like the rear triangle is offset. Doing some research I know it has an offset to compensate for the tires. But can that be the reason for the crank arm clearance? The rear triangle donít look bent or awkward in any way. And the tire is perfectly centered in the triangle.
    Attached Thumbnails Attached Thumbnails Rear triangle to crank arm clearance-94bfdd84-ab4c-4ce6-896b-ff42cf472259.jpg
    Rear triangle to crank arm clearance-93634bb9-1a84-44f1-b2a6-be62b34300a7.jpg
    Looking at it more it looks like the crank side is slightly wider to compensate for the spacer that brings out the rear sprocket. Which could cause that offset too.
    Attached Thumbnails Attached Thumbnails Rear triangle to crank arm clearance-7ce4473b-bf84-4721-bb2d-811274450bc9.jpg
    Rear triangle to crank arm clearance-356c08db-e04f-4735-b133-554cb1da8886.jpg
    Rear triangle to crank arm clearance-01b5f919-22f7-41e7-9bba-994ad1614baf.jpg
  1. 951 Crank Arm Clearance Issues
    By stunzeed in forum Intense
    Last Post: 05-30-2011, 01:59 AM
  2. DW link rear triangle crank clearance
    By edubfromktown in forum Turner
    Last Post: 02-13-2011, 02:45 PM
  3. About to replace a 110 mm driveside crank arm with a 113 mm arm
    By mikelikebike in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 06-21-2008, 04:37 AM
  4. Replies: 0
    Last Post: 07-18-2007, 08:42 AM
  5. Enduro rear triangle vs. SX Trail rear triangle
    By Scary Mc in forum Specialized
    Last Post: 03-30-2006, 04:04 PM
Members who have read this thread: 39
