Rear rack options for the Pugs?- Mtbr.com
Results 1 to 12 of 12
    Reputation: trrubicon06's Avatar
    I've searched through as many threads as I could find and only came up with 2 racks that I know work. There was a few others, but they were unclear and had no pictures. I know there is the Surly Nice rack and the OMM racks, But I'm looking for a more economical option for a rear rack. I'd like something in the $50 or less range, hold decent weight, allow use of small panniers, and be lower to the tire. I found a bunch from a company named Axium that claim they hold up to 150lbs, but I'm not sure which ones would work.
    Thanks in advanced and I appreciate any thoughts on the subject.
    bored ex-shop rat
    Reputation: velopax's Avatar
    Good job!
    OK the rack cost more than 50$ but can cary 40kg, Tubus Locc
    The capacity that Axiom claimed on some rack are far from reality
    Life is like a ten speed bicycle. Most of us have gears we never use. Charles M. Schulz (1922 - 2000)
    Well, I'm not exactly stuck on the $50 range, but I don't plan on using it a lot. I have a couple trips I'm planning once the Pugs is built and the rack and some pannier bags would be nice to have. I just don't see the need to spend over $50-$80 on something that I'm not gonna use a great deal. Is there a big difference in the way a rack mounts up to the Pug then other bikes? I know usually they are attached at the dropouts, but on the Pug they are further up.
    bored ex-shop rat
    The Jandd standard is a good alternative
    Self-defeatist
    Reputation: CLONG's Avatar
    Nov 2006
    Quote Originally Posted by velopax
    There's a Standard and an Expedition in the sales section of the website.
    http://www.jandd.com/detail.asp?PRODUCT_ID=FRSTD2NDS
    http://www.jandd.com/detail.asp?PRODUCT_ID=FREXP2NDS
    I'm covered in beer.
    Try one of these, fits my fatbike nicely and was cheap.
    http://www.rei.com/product/789676
    Home of the Gravedigger
    Reputation: jkaber's Avatar
    Nov 2006
    It's not cheap, but I do love my OMM Sherpa rack. I like how it mounts to the rear canti posts on the pugs frame. Very sturdy and fairly light.
    <a href="https://s427.photobucket.com/albums/pp356/jkaber/?action=view&current=004-3.jpg" target="_blank"><img src="https://i427.photobucket.com/albums/pp356/jkaber/004-3.jpg" border="0" alt="Photobucket"></a>
    runs with scissors
    Reputation: dosbugs's Avatar
    Topeak Explorer rack works fine on a Pugs and 9zero7 running 100 mm rims, you wonít even need the disk brake version of the rack.
    http://www.topeak.com/products/Racks...ack_w_o_spring
    Sorry not the best pics of the rack, the same rack was mounted on both bikes. Install is straight bolt-up nothing custom with one exception, because both bike have offset rear ends the first bolt up the bottom of the rack to the frame and bend the whole thing over about an inch so that itís centered over the wheel and then bolt up the top.
    32$ for a no drama solution not to bad?
    http://www.rei.com/product/697821?pr...:referralID=NA
    The front rack is a Delta mega rear rack
    http://www.deltacycle.com/Megarack-Sport
    Attached Thumbnails Attached Thumbnails Rear rack options for the Pugs?-2010_01020019.jpg
    jkaber- I do like how the OMM racks mount, but the Sherpa looks too small to me. I'm gonna be around your area from this Thursday to next Tuesday...going to see some friends in Denver.
    dosbugs- Do you have any pics of the Topeak mounted on a Pug?
    I'm looking for pictures mounted up also. Seems like not many companies have pictures of the racks installed.
    Reputation: dudicus's Avatar
    I already own a Tubus Logo Expedition Rack for my Brodie Hardtail and love the set-back bars which also lower weight distribution and give more leg clearance. I'll be building a fatbike this spring and haven't yet settled on a rear rack option until NOW! After pulling up a technical drawing of the Locc from Tobus and discovering rack width spacing of 120mm which gives ample room for stuffing fatties between I'm sold again with Tobus and German ingenuity. I'm guessing from the picture velpax posted that's the 28" 700c model rack with probably 3+ inches of headspace above the tire to rack. My personal riding requirements for an MTB/touring are panniers and or grocery panniers loaded to max. weight for camping trips and in-town runs to the local markets. I don't ever see any winter camping in my future or loading my bike down with weight when I'm wanting not to break through a snow pack. So the weight weenie factor can be thrown out the window here for a stout well built rack, and in reality how much weight are we realy fussing about? A couple grams or a whole fricken once! Thanks velpax for sharing your pic
    bored ex-shop rat
    Good job!
    Quote Originally Posted by dudicus
    It's a 26" Locc and you need also the foot extension part (Art.-No: 70024) to clear
    the brake caliper, maybe with 160mm rotors it will fit but I have 203mm rotors and
    I removed the mounting plate for the lock bracket with a dremel
    Feb 2012
    $24.99- Problem Solved
    Check out this rack from Performance... $24.99 and strong. No modifications to fit. Carries heavy saddle bags very well. TransIt TD-1 Rack
    Attached Thumbnails Attached Thumbnails Rear rack options for the Pugs?-wp_000021.jpg
