Rear Rack Issues - 2016 Blackborow- Mtbr.com
Results 1 to 6 of 6
    Reputation: farleybob's Avatar
    May 2012
    I've got a 2016 Salsa Blackborow with 27.5 x 4.5 Barbegazi's installed. The Alternator Rack from Salsa would not clear the tire, not tall enough.
    I ordered the Blackburn Outpost fat bike rack because of the adjustable design. However, this rack will not work when mounted to the top alternator bolt as it places the rack sides too far apart for the top deck to connect! I'm thinking of cutting off the "stand off" part of the lower mounts so I can bring the sides in closer together. Thoughts?
    Sent from my SM-G950U using Tapatalk
    I AM FAT!
    2018 Salsa Blackborow Mid
    Sep 2013
    Look at the Surly Rear Disk rack. I have one on my ICT and will check to see if it would work on my Blackborow.
    The Old Man Mountain Phat Sherpa works, thatís what I had on mine with 100mm rims and 2XL tires and it had plenty of clearance.
    Sep 2013
    I think the Surly rack would work just fine! You probably would have to get a seat post clamp like one Salsa sells.
    May 2005
    I run the alternator rack on my Blackborow with 2XLs...
    I used rubber coated stainless steel P-clamps in order to move the lower mount location up on to the SST. This way I can clear huge tires.
    This is absolutely a stronger, and more durable solution than cutting up your blackburn rack.
    Works great and cost me about 4.50 USD total.
    Jan 2009
    FarleyBob
    Nice PVC pipe bike racks, could you post some photos of it without bikes
  1. Blackborow meets 190 Alternator Rack
    By FatBike&SlenderWoman in forum Fat bikes
    Last Post: 10-18-2018, 01:13 PM
  2. Dropper post for 2016 Blackborow
    By SalsaSalsa in forum Fat bikes
    Last Post: 02-02-2017, 12:37 PM
  3. Replies: 11
    Last Post: 01-05-2017, 01:40 AM
  4. Anyone on a 2016 Salsa Blackborow sus GX1 with pic
    Last Post: 12-30-2016, 07:51 AM
  5. Roof Rack Issues vs. Spare Tire Issues?
    By AmishAirline in forum Cars and Bike Racks
    Last Post: 04-27-2015, 05:54 AM
