Rear fender that stays in place?- Mtbr.com
Results 1 to 12 of 12
    Bicyclochondriac.
    Looking for a rear fender (not full coverage) for fat tires that does not break in 3 rides and STAYS IN PLACE.
    I struggled for years to find a fender that would stay put during trail riding on my HT 29er. Probably tried 6 different ones. The problem was always the crappy clamping mechanisms. Most plastic ones could never be tightened enough to stay in place in rough terrain and anything that uses a web strap is beyond useless in my experience.
    I had decent luck with one staying in place on my 26” trail bike from Crud (plastic, but a better clamp design) but that eventually broke. I would try one again, but it does not look like they make one for the back of a fat bike.... or do one of their other ones work?
    Also, I want a LONG fender. One that goes back as far as the back of the wheel (or close to it).
    Any suggestions would be welcome.
    Thanks.
    The PDW Mudshovel works well for me (and has for a few years). The only time it moves is when I accidentally kick it when throwing a leg over the bike.
    Jason
    Disclaimer: www.paramountfargo.com
    Reputation: Legbacon's Avatar
    https://www.themudhugger.eu/shop
    The 29 Mudhugger with that Fatbkike extension.
    Formerly Travis Bickle
    Team Robot. "modulation is code for “I suck at brake control.” Here’s a free tip: get better."
    PDW mud shovel has been ok for me after modification. V1 clamp was no good for trail use. V2 was marginally better. I cut apart V1 and slotted in a hose clamp. Now it doesn’t twist or bounce around.
    Human Test Subject
    Reputation: Volsung's Avatar
    My mudshovel is cracked and the hardware is rusty but with enough electrical tape it stays in the right spot.
    Bicyclochondriac.
    Quote Originally Posted by Travis Bickle View Post
    Interesting. I like the look of that.
    You’ve had good luck with it? (EDIT: nevermind, I searched and see that you have used them and are a big fan)
    Any issues getting it to stretch to fit a fatbike’s seatstays? Or does some heat take care of that?
    FWIW, this is most likely going on a Wednesday.
    Elitest thrill junkie
    Reputation: Jayem's Avatar
    I use a fat front fender on the rear, works good, stays in place. I top it off with a seat-fender.
    The tape is just me being lazy and not using the velcro.
    Quote Originally Posted by kapusta View Post
    I have never had a fat bike, but they are flexible.
    Reputation: dbhammercycle's Avatar
    I've liked the PDW front and rear mud shovels. The V1 clamp worked well until worn and fit a piece of inner tube to get it to stay until the fabric strap broke. Got a new style clamp when it was mentioned for free, nice customer service! I've used some of the foil/aluminum tape to fix cracks as it adds some reflectivity for commuting. I recommend the fender to anyone who asks.
    That said, if had eyelets like the Wednesday I might try to find a full coverage fender. speaking of which, any know what happened to Big O Manufacturing?
    I don't know why,... it's just MUSS easier to pedal than the other ones.
    Sep 2014
    Mudhuggers are what I’m happy with after trying Mud Shovels. A little pricing but they handling rough terrain well.
    Attached Thumbnails Attached Thumbnails Rear fender that stays in place?-bfb47bb3-e0a3-4c40-8f9b-019db2bb141e.jpg
    Fat and bouncy
    Reputation: JackWare's Avatar
    Aug 2016
    I see you said that the Crudcatcher broke eventually but I've used a standard 29er Crudcatcher on my 4" tired Nutrail with no problems for a couple of years and it's the correct width, though it's too narrow for 4.8".
    Attached Thumbnails Attached Thumbnails Rear fender that stays in place?-dsc_0009.jpg
    What a perfect waste of time
    Oct 2013
    I put both a front and rear fender on the rear of my bike. The lower part is a front fender which bolts nicely where a caliper brake would go on a road bike. I then drilled a hole at the front/bottom and bolted it to the frame where a kickstand would go. This part is pretty stable.
    The rest of the rear is a seatpost mounted rear fender with a plastic clamp that the OP does not like. I could bolt the 2 halves together to strengthen the top part if it becomes necessary.
    The very back of the top fender is a black plastic folder that I cut up and taped in place. I could have mounted it a bit better, I'm not yet sure if I am keeping the extension.
    Rear fender that stays in place?-2019-01-06-19.13.15-custom-.jpgRear fender that stays in place?-2019-01-06-19.13.55-custom-.jpg
    Name:  Capture (Small).PNG
    Not enough rides in to know if it is strong enough.
  1. Replies: 2
    Last Post: 12-26-2011, 01:19 PM
  2. Replies: 0
    Last Post: 03-10-2008, 12:13 AM
  3. Replies: 0
    Last Post: 03-09-2008, 11:53 PM
  4. Quick question: flux stays = 06 spot stays???
    By swan lee in forum Turner
    Last Post: 01-28-2007, 02:04 PM
  5. Wishbone stays and A-stays..
    By mafia6 in forum General Discussion
    Last Post: 03-24-2006, 07:39 PM
