Rear axle/chain issues- Mtbr.com
Results 1 to 2 of 2
    Nov 2015
    I was riding to work yesterday and the wendigo rear axle came loose and slipped the nut area that it screws into on the frame. Nothing catastrophic . I was able to rethread the axle and head the last block to work. No observable damage, but the ride home and the ride in this morning, the chain has been consistently slipping every 8-20 pedal rotations. I am due for a pre-paid tune-up from performance, but thought I would check here to see if there were any thoughts on it.
    Reputation: watts888's Avatar
    Oct 2012
    probably bent the derailleur hanger a little bit. The LBS should be able to fix it with a simple alignment tool. Lot of possibilities with the derailure. Could be a simple adjustment of the shifter barrel end would fix it.
    "a hundred travel books isn't worth one real trip"
  1. Sun Ringle Axle Issues - QR vs 142
    By Biopace in forum Wheels and Tires
    Last Post: 11-17-2016, 11:45 PM
  2. HD3 Rear Axle Alignment issues??
    By neilether in forum Ibis
    Last Post: 02-20-2015, 01:25 PM
  3. Hub axle WANTED!! Reynolds hub rear axle!!
    By sccott in forum Wheels and Tires
    Last Post: 09-24-2013, 12:19 PM
  4. Rear Derailleur/Chain Issues
    By jaybear in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 04-08-2012, 06:23 PM
  5. Hope Pro 2 rear axle upgrade? install Evo bearings and axle?
    By KrisRayner in forum Wheels and Tires
    Last Post: 02-24-2012, 03:05 PM
