Raceface Turbine Cinch Crank Issues- Mtbr.com
Results 1 to 8 of 8
    I have had my Turbine Cinch crankset for at least 3-4 seasons I think, and recently it has been a little b!tch. I cannot keep the chainring nut tight for more then a handful of rides rides, and the preload adjuster keeps backing off.
    The last two times I have serviced the crankset they were complete tear downs, and detailed cleanings. Blue loctite was used on everything that had threads and grease was applied as needed. Torqued to spec with calibrated wrench. I even spit on it a few times for good measure.
    Any tips?
    Reputation: tyriverag's Avatar
    Jan 2014
    Yo Jon, I was just looking at taking apart and cleaning RF Turbine Cinch crank and BB on my fat bike. Sucker is on their tight, any trick to loosening with the 8mm hex? Do I need the 16mm to loosen the cap first?
    Also, which grease do you use?
    Update: sorry for possibly hijacking your thread.
    it's a challenge some of us are ultimately worthy of.
    I loosen and back the collar off first, then usually use a long breaker bar w/ and 8mm hex socket to get the crank arm off. No need to do anything with the 16mm.
    I have had good luck with Phil Wood waterproof grease. I'll shoot you a FB message.
    Thingamejigger
    Reputation: Flying_Scotsman's Avatar
    Do you have the plastic newer preload? You can get the Cane Creek ewings preload adjuster as a stand alone, aluminium and a machine screw, might be a bit more robust.
    Metal preload adjuster.
    Sep 2013
    Quote Originally Posted by Flying_Scotsman View Post
    Just picked up one of these. Going to install it over the weekend!
    Reputation: dRjOn's Avatar
    id suggest a hollowgram lockring and wave washer.
    ^thanks for the pics....I'll have to check that out!
  1. Raceface Turbine Cinch Cranks issues
    By buddiesconfusion in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 07-19-2018, 06:10 PM
  2. Easton 38T+ 1X Cinch Ring on Race Face Turbine Cinch Crank?
    By Sablotny in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 01-10-2018, 07:22 PM
  3. RF Turbine EXI vs Turbine Cinch crank stiffness?
    By jgusta in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 12-28-2015, 01:10 PM
  4. Next SL Cinch vs Turbine Cinch
    By Legbacon in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 05-27-2015, 11:55 AM
  5. Replies: 2
    Last Post: 12-15-2014, 12:46 PM
Members who have read this thread: 87
