Rabbit Hole 26" on Pugsley- Mtbr.com
    May 2010
    Tried to search for this, but all that comes up is Krampug set ups on 29" rims.
    On my Pugsley, I've got ML for winter rides and RH 29 for summer. I also want to add another 26 fat for summer riding (for more chunky trails). I thought about going with another set of ML. But I am thinking of giving Rabbit Hole's in 26" a try. What I don't know is, how well the offset of a smaller rim will work out. Do you think this is worth a try to save ~200g?
    I will set this up with my favorite summer fat tire, Jumbo Jim's. Yes, I have run 3.8" tires on 50mm rims in the past. Not AS ideal as 65mm rims, but not bad, either.
    Thanks for any input.
    Reputation: Redlands R&C's Avatar
    Dec 2013
    Just looking at the e.r.d. and the offset, I think it probably would work out ok. Might be a little low on tension on one side (drive) when built up properly, but should be fine. Unless maybe you are a bigger rider, or mega aggressive? I'd say give it a shot, it would probably give a nice round tire profile which would be pretty fun and maybe work out well for your chunky trails.
    Silly bike things happening.
    This place needs an enema
    Reputation: mikesee's Avatar
    Aug 2003
    I've built lots of these. Works out fine.
    As an alternative, I have several sets of Neon trials rims laced offset for a Pugsley. They are light and stiff, but tubeless is not particularly easy.
    "Wait- I am confused" - SDMTB'er
  1. Replies: 3
    Last Post: 03-22-2017, 04:29 AM
  2. Pugsley 29+ Rabbit Hole alternatives?
    By EssexBoyUK in forum Surly
    Last Post: 06-24-2016, 06:55 PM
  3. Dirt Wizard 26" + Rabbit Hole 26"?
    By r1Gel in forum 27.5
    Last Post: 12-18-2013, 03:59 PM
  4. Replies: 6
    Last Post: 11-04-2013, 02:35 PM
  5. Knard/rabbit hole on a Pugsley
    By roobydoo in forum Fat bikes
    Last Post: 12-07-2012, 06:00 PM
