quick fork question- Mtbr.com
Results 1 to 3 of 3
    quick fork question
    I got a chance to ride a Pugs yesterday and have been bitten by the fat bug. Quickest way for me to get into the snow is to replace the front end on my Gary Fisher and go fat up front, studded and skinny in the rear.
    I'm headed for an Endo on an 80mm rim on the front. Can I fit that combo on a Pugsley 100mm fork, or do I need to go to the 135mm spacing?
    I know I lose the front/back interchangeability with the 100mm fork. OTOH, I can build up or buy a standard 29er wheel and swap that in instead of changing the fork when I don't want fat.
    Anyone know about the fit on the 100mm fork?
    LATER:
    Found the answer in Surly's own catalog: both forks will fit a 4" tire, but the 100mm may require a bit of finesse to get it into. I pulled the trigger in my half-fat-Fisher project. 100mm fork, 80mm wheel, Endo, etc., are all on their way.
    TIA,
    Dave
    Rochester, NY
    Quote Originally Posted by Element6
    The endo fits in the 100mm fork on a viscious 80 and can be removed without having to let air out of the tire. This is the combo I'm running without issue. The 100mm forks are a bit hard to come by these days. If you go to a 100mm rim you will have to release some pressure to get it out of the fork.
    If you would be interested in a new 135mm gray pugs fork I have one for cheap. $75 shipped via UPS to the lower 48.
    Turner Burner, Polished
    Salsa Mariachi 2
    Salsa Mukluk 2 Custom
    Bucksaw - Future Ride
    Thanks mtn_man2. That's the info I was looking for. The half-fat Fisher is a go.
    I'll pass on the 135mm fork, thanks, Got my heart set on the 100mm.
    Dave
