Question on brake caliper adapter for the Bluto- Mtbr.com
Results 1 to 12 of 12
    Dec 2014
    We the people ... Question on brake caliper adapter for the Bluto
    So I just bought a Bluto and am installing my XT M8000 brake caliper on it. As I am using a 180mm rotor on my DT Swiss hub, I obviously need an adapter to lift up the caliper a bit. I am using the regular XT / XTR adapter (one end is about 10mm and the other end is about 5mm) but it seems that the caliper is just not sitting right. What am I doing wrong?
    I have searched the Internet and could not find any pictures of a bluto with the brake caliper.
    Nutrailer
    Reputation: JackWare's Avatar
    Aug 2016
    Is that the same set up as the Nutrail Race?
    I have a 203mm adapter coming from China. I'll let you know if there's something not right about it
    Reputation: Misterg's Avatar
    Jul 2014
    The correct adaptor should work (+20mm). What is the part number of the adaptor are you using? Is it the correct way up?
    Photo of Bluto + caliper:
    (Note that this is actually the wrong adaptor - it's +23mm. The correct one looks the same, but I don't have a photo Also, I changed to Shimano Deore brakes when the pads in the Avids wore out - they fit exactly the same as that photo.)
    Quote Originally Posted by paxfobiscum View Post
    Are you sure it's an adapter for 180mm front and not rear? They are not the same.
    Dec 2014
    The Shimano F180P/2P adapter works fine on my Bluto with XT M8000.
    Nutrailer
    Aug 2016
    Quote Originally Posted by kidd View Post
    When it fitted could you post a pic- as I'm interested in this mod
    many thanks
    The adapter worked out better than the camera on my phone. I can only take selfies.
    Jul 2014
    A 203mm adaptor (presumably 180 to 203, so +23mm, rather than 160 to 203 which would miss half of a 180mm disc!) is not ideal for a 180mm disc, as it makes the pads run off the edge of the disc by ~1mm. It is what I have in the photo I posted above - it was sold to me as a +20mm adaptor (when I figured out why the pads were not lined up with the disc I returned it).
    To run a 180mm disc with Blutos, you need a 160 to 180mm (i.e +20mm) post to post adaptor. Shimano do two types: one with two bolts that mount both the caliper and the adaptor, and one with four bolts where the caliper and the adaptor are mounted separately:
    2 bolt: SM-MA-F180-P/P2
    4 bolt: SM-MA-F180-P/P
    Question on brake caliper adapter for the Bluto-523525d1267219278-180mm-shimano-disc-brake-adaptor-fsa-afterburner-386-17301.jpg
    (Similar parts are available from others)
    I'm using the SM-MA-F180-P/P2 with a 180mm rotor and the Bluto, and it works just fine.
    Pic of my 203mm setup. Some juicy 7s lined up perfect with cone washers top and bottom. These XOs only line up with no washers on bottom.
    Dec 2014
    Quote Originally Posted by Misterg View Post
    Nutrailer
    Aug 2016
    And here's a close up of the mod on my Nutrail
    Name:  disc conversion.jpg
  1. Replies: 2
    Last Post: 11-04-2015, 07:14 AM
  2. Avid brake caliper adapter...
    By radnur22 in forum Brake Time
    Last Post: 02-06-2015, 11:15 AM
  3. brake adapter question
    By dwyooaj in forum Brake Time
    Last Post: 12-18-2013, 06:49 PM
  4. Shimano Brake Caliper Adapter Installation
    By dshoe70 in forum Brake Time
    Last Post: 11-12-2013, 01:19 AM
  5. Replies: 18
    Last Post: 11-13-2011, 07:58 AM
Members who have read this thread: 7
