Q-tubes superlight question- Mtbr.com
Results 1 to 20 of 20
    Reputation: Melll's Avatar
    Jan 2015
    I would like to replace my tubes with something lighter when I replace the rim strips on my Fatboy 24.
    The Q-tubes Superlight only come in 24 x 1-1/8 inch
    Q-Tubes Superlight Tube (24 x 1-1/8 inch, Presta Valve) - cyclesmith.ca
    Would these work in my 24x 4" Ground Controls? I'm a small female rider and I ride almost exclusively on snow at about 3 - 4 psi.
    Reputation: Xethur's Avatar
    Dec 2014
    If you really are looking for 24s then I would look to specialized. They have a 24 2.4-3.0 that somewhere I saw weighted in at 235g. They are a bit more expensive but they should be trouble free. And they will for your 4" tires.
    Xethur
    Dec 2014
    Which Q-tube or Specialized tube can be used for the Ground Control 4.6" tires?
    I recently put in the Surly Ultra-Lights but have been thinking about going a little lighter yet on my tubes.
    A friend uses q-lites in his gc's no problemo.
    rog
    Nov 2007
    Try a different store. The Q-tubes lites you want are these: Bikeman Q-Tubes Super Light 26 inch x 2.4-2.7 inch 32 mm Presta Valve Tube
    I used these for years until I went tubeless. Got lots of flats, I have to say.
    Reputation: Swerny's Avatar
    Quote Originally Posted by SmooveP View Post
    The OP has the Fatboy 24...meaning 24 inch wheels.
    She doesn't need 26 inch tubes
    OP, i found these on the Jenson website, not SL, but likely still lighter than what you have now:
    Q-Tubes Standard 24" Presta Tube > Components > Wheels, Tires and Tubes > Tubes | Jenson USA
    I wouldn't run the 1 1/8 tubes you mentioned.
    Mike
    Toronto, Canada
    2017 Trek Farley 9.6
    2017 Diamondback Haanjo Trail Carbon
    2016 Scott Solace 10 Disc
    Nov 2007
    Ah, missed the 24 part.
    Jan 2015
    Yes, I do need 24" not 26" tubes.
    Thanks, I thought the 1 1/8 might be too much of a stretch. Is there anywhere I can find the weight for the standard Q-tubes?
    Jan 2015
    Quote Originally Posted by Xethur View Post
    Thanks, I'll go looking for those
    Quote Originally Posted by Melll View Post
    my trusty updated Q catalogue sez 246 grams for the 24 x 2.4-2.75 standard schrader valve (only). retail about 6 bux. prolly half of what a special-ed toob sellz for.
    rog
    turtles make me hot
    Reputation: NYrr496's Avatar
    How about just running split tubeless?
    I like turtles
    Perpetual n00b
    Reputation: dgw2jr's Avatar
    Quote Originally Posted by NYrr496 View Post
    This. It's been the most effective solution for me.
    The leg bone's connected to the Cash Bone!
    Jan 2015
    Quote Originally Posted by newmarketrog View Post
    my pleasure
    rog
    Jan 2015
    I think I'll still go with tubes for now, but what size tube would I use for 24" tires if I did want to go the split tubeless route?
    turtles make me hot
    I use the Q Tubes 24" tube for split 26". I'm not sure how well a 20" would work. Maybe a 24.
    I like turtles
    Perpetual n00b
    Go with the 20 inch tube. The 24 inch tube will be too loose fitting.
    Universal Cycles -- Q Tube - Presta Valve
    Get the widest one they have, which at the moment is 20"x 1.75-2.125" 32mm PV.
    Jan 2015
    Quote Originally Posted by dgw2jr View Post
    Jan 2014
    Check out Schwalbe tubes. I bought 4 tubes for the 26" wheels and they all ran less than 190 grams. I ended up going to schraeder valves in case I decided to add slime.
    Tubes have held up even with the light weight.
    Dash Pt. State Park (Tacoma), Big Sky Montana during Snowboard Season, Duluth Mn, a couple of times of year incl. Xmas.
    try anything on a bike
    Reputation: blue_biker's Avatar
    Why not do regular tubeless, not the split tube. At 24 inch tires, the gorilla tape method is quite simple.
    The most freeride like fat bike I could make with available parts...
  1. Superlight question
    By feltbee in forum Santa Cruz
    Last Post: 08-08-2014, 04:14 PM
  2. From Superlight to Solo Question
    By glenj in forum Santa Cruz
    Last Post: 08-19-2013, 04:13 AM
  3. Superlight 29 question
    By TwoNeener in forum Santa Cruz
    Last Post: 05-13-2012, 06:05 PM
  4. Superlight Question
    By illini in forum Santa Cruz
    Last Post: 11-15-2011, 12:30 PM
  5. I'm getting a Superlight. Sizing question now
    By ernie00 in forum Santa Cruz
    Last Post: 06-15-2011, 10:06 AM
