Pugsley Fork Options- Mtbr.com
Results 1 to 3 of 3
    Oct 2014
    I'm currently building a Krampug Pugsley running 29x3" tyres but quite keen to be able to run a standard dynamo hub. The Pug 100mm spaced fork doesn't have the bottle cage mounts which I'm quite keen on so looking at fitting ECR or Ogre forks instead.
    Will there be a problem with doing this? Probably a dumb question but don't know a great deal about frame geometry.
    Pug and Ogre fork has 43mm rake whereas ECR fork has 47mm. All other measurements appear to be the same. Will there be much difference in the handling between the measurements?
    Any input greatly appreciated.
    Cheers
    Chris
    Thingamejigger
    Reputation: Flying_Scotsman's Avatar
    How about just fitting the rivnuts into the standard fork?? Coastkid has done this on many of his Pugsleys.
    Reputation: AlexCuse's Avatar
    Quote Originally Posted by Flying_Scotsman View Post
    This is a good idea.
    I would worry more about the axle to crown measurement changing than the rake. Changes there feel a lot less subtle to me.
    Yeah I only carry cans cause I'm a weight weenie.
  1. Replies: 43
    Last Post: 06-15-2015, 10:05 AM
  2. Pugsley Carbon Fork Options - Help!
    By abbeytrails in forum Fat bikes
    Last Post: 02-25-2015, 06:07 PM
  3. New Pugsley - Front Der Options?
    By green mt. boy in forum Fat bikes
    Last Post: 11-03-2013, 05:53 AM
  4. Pugsley Crankset Options
    By AMessy in forum Fat bikes
    Last Post: 10-04-2013, 06:18 PM
  5. Pugsley Handbar Options
    By 50 mission cap in forum Fat bikes
    Last Post: 09-27-2013, 01:48 PM
