pugs bb- Mtbr.com
Results 1 to 12 of 12
Thread: pugs bb
    pugs bb
    botton brackets
    hi guys - I know I will need a 100mm bb for a pugsley - I have a good FSA carbon crankset lying around - but its an octalink - can I get an octalink bb 100mm to mate it with?
    No, that's not phonetic
    Reputation: tscheezy's Avatar
    No. Square taper or Isis only.
    My video techniques can be found in this thread.
    bored ex-shop rat
    Reputation: velopax's Avatar
    Caution;  Merge;  Workers Ahead!
    Quote Originally Posted by cozz
    botton brackets
    That's a short list of current 100mm BB & cranks options:
    - Phil Wood square JIS BB with some square cranks
    - Truvative GigaPipe Team DH or FSA Platinum Pro DH ISIS BB with some ISIS cranks
    - Race Face Atlas FR & Diabolus DH cranks/BB sets (external bearing BB)
    - Profile Racing BMX cranks/BB set
    - The Hive 15G cranks/BB set
    - Truvativ Howitzer Team BB with some Truvativ cranks with Howitzer interface
    - Surly Mr.Whirly cranks with some external bearing BB
    Life is like a ten speed bicycle. Most of us have gears we never use. Charles M. Schulz (1922 - 2000)
    Reputation: timroz's Avatar
    Feb 2007
    I ruined a Truvative 100mm isis bb in 50 miles. And I'm a weakling.
    bored ex-shop rat
    Quote Originally Posted by timroz
    If you use ISIS cranks, go for the FSA
    Jan 2005
    I sure hope the FSA is better!
    no dabs
    Quote Originally Posted by velopax
    action tec square taper with most square taper cranks as well.
    no dabs
    Mine is still doing fine after a season of mud, and at ~230-250 lb, I (used to) break everything. Certainly the quality could be variable, but it seems like a good design. The design does seem to depend on the bb shell length/spacer combo being perfect... If your shell plus spacer plus etype bracket stack is the slightest bit too long, it would ruin the bearings in short order. I had to face my shell a hair to make the provided spacer the right thickness.
    bored ex-shop rat
    New question here.
    Quote Originally Posted by rocwandrer
    I can't find a 100mm BB option on the Action Tec site
    Reputation: bighit's Avatar
    my FSA is 1 yr. old and is getting gritty. i dont plan on using it for much longer.
    2013 mongoose Fat bike
    2012 Moonlander.
    http://undergroundvelo.proboards.com/
    no dabs
    the Ti spindle version is straight with spindle collars, meaning you can use it with a 100 mm shell, and with a long spindle, it will just be better supported (last longer, be a little stiffer) than in a 68 or 73mm shell, but otherwise function the same.
    I picked up a Race Face JIS square taper on E Bay. I'm using a Kooka Crank on Fat Back and used both on a Pugs before that.
