Pug Ops with Tubeless Clown Shoe and Big Fat Larry- Mtbr.com
    Reputation: Surlyrider's Avatar
    Sep 2014
    Hi everyone. I am new here, so yell at me if I am doing anything wrong with posting here. Yesterday I put a Clown Shoe/BFL on the front of my 2014 Pug Ops, and thought I would share the images here, since I have not been able to locate any on the net (only Necromancers with the Clown Show/BFL). The rear is still the stock Rolling Darryl/Nate. Both are tubeless using the Gorilla Tape method. I had to use two strips of overlapping 3" tape for the Clown Shoe. I seen a few who had trouble seating the tubeless Clown Shoe, but I nailed it the first shot. For some reason it was easier than the Darryl/Nates, which took a few shots to seat. When I first setup the BFL on the CS, with maybe 12psi in it, it did not look much larger than the RD/Nate, but after inflating to 30psi, it got huge! Not sure if it is in my head, but I think after converting to tubeless, that it got even bigger. I should have taken some measurements before and after. I have also included an image of the stock RD/Nate on the front for comparison. Note that the Clown Shoe does not come in canvas green like the Pug Ops Rolling Darryl, so went with black. Not sure if I will keep the back in green yet or not, kinda liking the frankenbike feel with the two different rims .
    Attached Thumbnails Attached Thumbnails Pug Ops with Tubeless Clown Shoe and Big Fat Larry-surlypugopspugsley.jpg
    how is it holding up? I'm having trouble with mine. It holds air fine at 8 psi, but once i go lower, it leaks pretty fast along the bead of the rim. THoughts?
    Sep 2014
    Also new here....I'm getting ready to pull the trigger on a $1400 Pug....can I do,the same thing to it?
    Reputation: ianick's Avatar
    Quote Originally Posted by homebrewtim View Post
    Yes, as long as it comes with the Moonlander Fork and not the Offset Pugsley Fork.
    Moonie fork:
    Offset Pugsley fork:
  1. Clown Shoe - who has them in stock?
    By mongol777 in forum Fat bikes
    Last Post: 11-02-2013, 06:47 PM
  2. Clown Shoe Build
    By Boatracer in forum Fat bikes
    Last Post: 03-06-2013, 10:21 PM
  3. Replies: 1
    Last Post: 11-26-2012, 03:47 PM
  4. Clown Shoe eta?
    By bdundee in forum Fat bikes
    Last Post: 12-11-2011, 02:48 PM
  5. Clown Shoe ERD?
    Last Post: 11-22-2011, 07:14 AM
