Pivot Les Fat Tire clearence- Mtbr.com
Results 1 to 6 of 6
    Jan 2009
    Been looking at the current Les Fat and it states:
    27.5" wheels with a 60-90mm rim, you can fit tires from 3.8" to 4.5"
    Anyone have this bike and run the larger tires?
    Nobody
    Reputation: Shamis's Avatar
    Apr 2015
    Are you asking specifically about 27.5 clearance?
    Hunt Hard, Kill Swiftly, Waste Nothing, Offer No Apologies...
    Jan 2009
    Yes, just 27.5 tire clearence
    Reputation: sherwin24's Avatar
    For posterity, on 65mm rims the 4.5 Barbegazi fit in the fork with the smallest clearance being 9/16" at top of the arch. In the rear they fit with sliders a couple clicks forward of halfway with 6-7mm of clearance at the cs arch. Clearance at sides is no problem anywhere.
    Jan 2009
    Thanks, just what I needed. Now, I wonder if the Gnarwhal tires will fit F/B...
    Those were @20psi for 10 days but unridden. I slid the rear all the way back last night to check how much clearance at max: 15mm. So the rear at max out matches the max clearance at the fork. So my guess is, yes a Gnar will fit, especially considering airing them down for snow pressure, but with studs? Another consideration is the CS length will be longer and bike slacker in general, if that matters to you. I like ride snappiness with the chainstays short as will fit, yet like the geometry feel on the bike with the sliders back, so usually end up about halfway or just shorter than that, so the Barbi's should work well hopefully.
  1. Pivot Les Fat
    By fc in forum Fat bikes
    Last Post: 12-10-2018, 04:37 PM
  2. Replies: 9
    Last Post: 08-06-2018, 06:32 AM
  3. Need feedback on LES / Les Fat
    By Bosco1911 in forum Pivot Cycles
    Last Post: 05-09-2017, 04:49 AM
  4. Pivot 429c or Rocky RSL BC, weight, mud clearence?
    By kaplanjoe in forum Pivot Cycles
    Last Post: 11-16-2012, 09:33 AM
  5. Replies: 10
    Last Post: 04-29-2004, 09:35 AM
Members who have read this thread: 59
