PF41 132mm Bottom Brackets: going the way of the dinosaur?- Mtbr.com
Results 1 to 3 of 3
    So I have (and love) a Salsa Blackborow (old school, not the longtail). I tend to keep my bikes for a loooong time, and therefore want to be prepared for any obsolescence.
    The weak link for the Blackborow as far as I can tell is the dependence on the 132mm PF41 bottom bracket, as I'm not sure there are any new bikes with this spec anymore. (The Surly ice cream truck used to use this and went to a 100mm threaded BB in its latest iteration).
    Is it time to stock up? Should I just get some extra bearings and not the cups? Go thread-together before those disappear? Should I be worried about the MWOD cranks or what might eventually replace them? Interested in what others have done here.
    Nov 2008
    I do not see the need to stock up. PF41 refers to the shell diameter, there are many versions that use the same cup with different length center sleeves. Currently there are at least a dozen different brands making bearings for PF41.
    BB86, BB92, PF24, PF90, BB104/107, PF121, BPF132 all of these use the same press fit bearings.
    Lucky neighbor of Maryland's Patapsco Valley State Park, 39.23,-76.76 Flickr
    That makes sense, thanks. I'd hope that there will be a supply of compatible cranks out there as well, that at least some used in 100mm threaded BBs would be long enough with he right diameter.
  1. alternative crankset for PF41-132 (Ice cream truck)
    By high_desert_mud in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 08-21-2018, 09:41 PM
  2. Replies: 2
    Last Post: 10-18-2016, 05:01 PM
  3. BB question - Les Fat & 132mm
    By Maadjurguer in forum Fat bikes
    Last Post: 04-14-2016, 07:49 PM
  4. Hollowgram Axles - 131mm vs. 132mm
    By Le Duke in forum Cannondale
    Last Post: 04-06-2016, 06:12 AM
  5. Replies: 14
    Last Post: 03-15-2016, 05:11 PM
Members who have read this thread: 30
