On One Fatty Wheel Conversion- Mtbr.com
Results 1 to 3 of 3
    Hi does anyone know if a 15 mm axle conversion is do-able on the On-One fatty standard front wheel.
    I thought I read somewhere that ******* end caps could be used but I can't for the life of me find the thread now.
    Seems like the standard bearings could take a through axle.
    Any ideas guys ?
    TIA
    Fat Biker
    try anything on a bike
    Reputation: blue_biker's Avatar
    no, the hubs on the Fatty cannot be converted. You will need to rebuild your wheels, either using a convertible hub, like Salsa or Hope and get the Hauck Engineering conversion kit with brake adapter/spacer, or just use a 150mm hub.
    The most freeride like fat bike I could make with available parts...
    OK, thanks. I thought I had read somewhere of an unofficial hack using the end caps off another hub set.
    Fat Biker
  1. Possible Fatty Fat Tire Conversion
    By kuan in forum Cannondale
    Last Post: 10-15-2016, 03:27 PM
  2. fatty bluto conversion help
    By stesteste in forum Fat bikes
    Last Post: 10-22-2014, 01:15 PM
  3. Fatty 29r or Moster 650b conversion
    By Ramjm_2000 in forum Fat bikes
    Last Post: 02-03-2014, 03:13 AM
  4. Easiest Possible FS fatty conversion Ive seen yet
    By Thumpy69 in forum Fat bikes
    Last Post: 03-29-2013, 05:07 PM
