OD of 40 and 42 tooth cinch chainring?- Mtbr.com
Results 1 to 7 of 7
    Mar 2015
    I am looking to fit a 40 or 42 tooth chainring to a fat bike in a sort of Monster-cross fatty build. looking to get more of a road suitable gearing option. I am currently running a Turbine cinch crank with 32T and it has lots of room to spare before contacting the chain stay. I am trying to get the biggest chainring possible with out buying a few and having to sell the ones i don't need. So if anyone could measure the OD of their 40T or 42T chainring that would be awesome.
    thanks in advance.
    Reputation: solarplex's Avatar
    Apr 2014
    Quote Originally Posted by Jefflinde View Post
    thanks in advance.
    40t sram is 6-5/8"
    42t absolute black 6-7/8"
    Fatbike, XC bike, Gravel Bike....
    Mar 2015
    Perfect. Thank you so much
    Nov 2016
    if you have a Cassette cluster with a 42 tooth cog on it
    you can always measure that.
    a 42tooth cog is just about the same size as a 42tooth chainring.
    Feb 2014
    Pretty simple math if you're into that. Teeth are spaced at half inch intervals to line up with our links. So a 40t ring had a circumference of 20". C = Pi x D or 6.37" in diameter.
    Mar 2015
    The biggest cog i have is a 38 and i figured there was a math trick but didn't know what it was. thanks again everyone for your help.
    Quote Originally Posted by Shinkers View Post
    Except the measured diameter above is 6.625". I suspect because the teeth stick out farther than the midline of the chain.
    Latitude 61
  1. RF Cinch w/ Bashguard vs non-Cinch
    By head in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 11-03-2016, 09:53 PM
  2. Replies: 23
    Last Post: 10-28-2015, 06:48 AM
  3. Next SL Cinch vs Turbine Cinch
    By Legbacon in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 05-27-2015, 11:55 AM
  4. Replies: 2
    Last Post: 12-15-2014, 12:46 PM
  5. Shredded 11 tooth cog, broken teeth on both 15 and 17 tooth cogs
    By tgmoe in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 04-17-2013, 09:43 PM
