New Fat Bike front rack for under a UK tenner- Mtbr.com
Results 1 to 10 of 10
    Reputation: Johnclimber's Avatar
    I've been looking at the Salsa Minimalist Rack but for the limited use it might get and the fact that it costs over 60 here in the UK, I thought I'd do a bit of a botch job using the 9.99 one that's on offer this week in Aldi, which I've used on the rear for several years.
    If it's available worldwide via other budget supermarkets it looks like this
    Salsa Minimlist rack 526 grams 66
    Aldi 9.99 rack original weight 1100 grams
    Aldi 9.99 rack now weights 650 grams
    It even goes around a BFL
    I drilled another hole in the silver bottom fixing strip (above shot) to rasie the rack a touch higher
    Excess weight trimmed and it's weight is straight over the bottom bolts
    So, as long as I don't overload it cable ties should be perfect for fixings and weight saving
    I cut a tiny square of inner tube and wrapped it in duct tape to stop rubbing.
    But from Coastkid's following post I'll be using the P clamp as shown on his link instead of the cable ties, Cheers Coastkid
    Any good?
    Strangelove
    Not bad at all. A simple P Clip wrapped around the rack and bolted onto the fork would be a neater solution that zip ties though. And safer too, you don't want a front rack coming loose.
    Reputation: coastkid71's Avatar
    yep, get a stainless P clip on Ebay. available in different sizes (buy to suit tube diameter),
    I also use these for bottle cages on forks etc...
    P Clips x 2 Pack 304 (A2) Stainless Steel EPDM Rubber Lined | eBay
    plan it...build it....ride it...love it....
    http://coastkid.blogspot.com/
    Cheers fella's
    I'll get one of those ordered tomorrow Bruce. I CBA going out to the garage again tonight
    Reputation: OFFcourse's Avatar
    That poor inner tube!
    Inner tube?
    Quote Originally Posted by Johnclimber View Post
    I cut a tiny square of inner tube and raped it in duct tape to stop rubbing.
    Bad taste I know
    Ah, i missed that bit John said about the inner tube,
    i hope he rapped it and had not `raped` it
    Wrapped!
    OK, so I failed English..........
    Nips up the page to edit [blush]
