Nate vs Bud/Lou- Mtbr.com
Results 1 to 21 of 21
Thread: Nate vs Bud/Lou
    Oct 2012
    Nate vs Bud/Lou
    Time for new tires! Here in eastern PA we don’t have maintained, groomed trails to ride on, so fat biking usually involves riding through a couple inches of fresh snow which can range from powder to slush. I am not sure how much flotation actually helps versus just having big nasty treads that move the bike forward and keep it moving in a straight line through variable crap. I don’t really care much about rolling resistance on hard surfaces if I can blaze my own trails through a few inches of snow/slush/mud.
    I was planning on putting these on 80mm rims, but also have a set of 65mms.
    What say you? Would the Nate’s work fine given that the snow isn’t deep? Or does the Bud/Lou offer more traction AND float?
    Nate offers great traction, kind of like a mini-Lou. Obviously Bud and Lou offer more float. I would say that Bud offers better lateral traction than Nate in the front (never ridden Lou in the front). Not that Nate really lacks for traction, but Bud is pretty exceptional in loose corners. (Note: I haven't tried Edna)
    Assuming you can fit a 4.8 in the back I prefer Bud/Lou to Nate in most snowy or loose conditions. But I weigh 240 plus all my gear so I tend to sink.
    I know a few riders running Bud front and Nate rear on their 170/177 rear axle bikes.
    Good luck choosing!
    Reputation: BIGHORN LEW's Avatar
    Edna 4.3 gets nate traction, but more float. Might be perfect for you?
    Oct 2012
    Thanks! Did not know about the Edna.
    The B/L combo is heavily discounted right now.
    turtles make me hot
    Reputation: NYrr496's Avatar
    I have not tried Edna but I consistently mount up Bud and Lou when the snow flies. They do no wrong.
    I like turtles
    Dec 2011
    I've tried several tires and I haven't been able to beat the Bud/Lou in snow. Awesome winter tires.
    Music & Bikes
    Reputation: fokof's Avatar
    IME Lou is a bigger/heavier Nate.
    Similar traction.
    Depends on what you prefer : flotation vs lighter weight ( Lou vs Nate )
    I run Bud & Lou in winter and JJ 4,8 / 4,4 in summer
    "There is a big difference between kneeling down and bending over" -FZ
    Jan 2015
    I picked up two 120tpi nates a month ago for $69 a piece. Theyve been good in the traction department and pretty fast rolling, but one of them leaks sealant at the bead all over on both sides while the other is bone dry. Seems to be holding pressure, but is just leaking sealant all the time.
    May 2010
    Given your situation, I don't see a reason why you need to go to a 5" tire. I'd stick to 4" Nates, personally. (Or Van Helga).
    Quote Originally Posted by pOrk View Post
    What rim and tubeless system? What sealant?
    Jan 2015
    Whisky carbon no9 70mm, whisky tape, stans, about 4.5oz.
    Interesting fact, one nate is different than the other. One says 3.8 and the other says 4.0, both 120tpi, just different sidewall text. You can see the seapage all yhe way around the bead on both sides. Set the bead at 25psi. Rode it 15miles yesterday and did a few chunky descents at speed woth about 10psi.
    Sep 2013
    Try switching to Orange Seal Subzero. I find the latest Stan's sealant to be useless...
    The system seems spot on. I'd agree on the post above regarding Stans.
    I bought a Nate recently when they went on sale, but it is still in the box. Can't comment on what its sidewall says. Have they modified the molding (ridges and hidden font) along the beads?
    Jan 2015
    Quote Originally Posted by bme107 View Post
    Im going to see about getting somenorange seal this week but tonight im going to setup a JJ 4.0 i have lying around.
    Nov 2014
    I run Bud / Lou in winter and a Nate in back in summer - for our riding here in CO I would not run a Nate in snow. There will be times you’d be wanting the Lou no doubt. Lou has gnarlier knobs and better flotation. And since you said you don’t care about rolling resistance - that seals the deal. Lou.
    Mar 2005
    Quote Originally Posted by CObikeman View Post
    Why?
    Plenty of us here in the CO mtns running Nates during winter and perfectly happy with them.
    May 2010
    Quote Originally Posted by Dr Sloth View Post
    Why?
    I’m just a state over from you and happy with Nate/VH as well. I had Lou/XXL/etc 5”+ tires. But in the end, Nate’s at low psi worked just fine without the weight/RR penalty getting to the trails or on the fast sections.
    Nov 2014
    Because many of the snow rides I do require max floatation and max traction. Would a Nate suffice? Maybe. But I want a tire that is awesome - doesn’t just suffice.
    Reputation: Dilligaff's Avatar
    Nov 2015
    Go with the Bud/Lou. I have Nates and love them, but they're no match for the traction and girth of the B/L. For winter, why settle.
    Nothing to see here, move along folks.
    Jan 2015
    I run nates and vanhelgas before that because I cant fit the 5” tires otherwise i would. but i can fit an edna and probably dunderand flow. Not much feedback on edna in the snow, but it looks like a good compromise for the 177 folk. Kind of like a bigger nate
    Reputation: calzonical's Avatar
    Aug 2005
    Edna review
    With 197mm frame I run Bud/Lou when snow is 5+ inches. Usually run 27.5 x 4.5 the rest of the time.
    I have run Lou/Lou and that's a whole lot of work.
    Back in the 170mm frame dayz I ran Bud/Nate and Nate was OK but it's no Lou. Swapped the Nate out for Lou on a Marge Lite - ding! ding! ding!
    *disclaimer: Above experience on CO snow.
  1. winter tire setup: nate/nate or nate/bud?
    By Rodney in forum Fat bikes
    Last Post: 09-18-2016, 11:07 AM
  2. Bud and Bud, or Lou for sand?
    By letitsnow in forum Fat bikes
    Last Post: 04-02-2016, 04:02 PM
  3. Rolling Resistance- Nate F & R vs Bud/Lou
    By nitrousjunky in forum Fat bikes
    Last Post: 12-22-2014, 04:15 PM
  4. Replies: 8
    Last Post: 01-12-2014, 10:16 PM
  5. Bud and Lou and OD Crank Yeay!
    By MasterOMayhem in forum Fat bikes
    Last Post: 08-15-2012, 06:30 AM
